Custom Intercooler Spray Bars.
Old 10-19-2012, 10:10 AM
Former Vendor
NitrousExpress's Avatar
Default Custom Intercooler Spray Bars.
I figured that I would share with you guy a intercooler sprayer that we just finished up for a customer.
We can built these thing so any shape and size that you may need, so if you are ever in the market for one give me a call and I can get you setup.
Trey
Old 10-19-2012, 11:12 AM
JoeyGC5's Avatar
Looks good.
How is Mr Wood doing these days?
Old 10-19-2012, 11:48 AM
nonnieselman's Avatar
Does one run a jet with something like that?
Old 10-19-2012, 11:50 AM
FormerVendor
Neal@NitrousOutlet's Avatar
open flow. no need for a jet. You want to get the most bars as possible
Old 10-19-2012, 04:01 PM
Former Vendor
There is no need to run a jet we use one of our smaller solenoids to restrict the flow down, it uses 150 hp worth of nitrous when it is being sprayed.
Trey
Old 10-21-2012, 11:09 AM
Ph.D. in HUBRIS
custm2500's Avatar
At first this seems to make sense. But then you realize that you could spray the nitrous into the engine and make 150 hp not the 20 it will gain from cooler temps. But honestly why not just put a 25-50 shot into the engine since it will require very little tune adjusting vs. cooling the inter cooler?
Old 11-13-2012, 12:41 PM
kush killer's Avatar
wondered the same thing myself
Old 11-13-2012, 01:04 PM
Unless someone uses it where Nitrous cant be used as an power adder.. Come classes are setup like that..
Old 11-13-2012, 01:11 PM
^^^ makes sense.. was thining of running one of these but, pretty sure ill jsut runnin a 50 whole shot
Old 11-14-2012, 12:11 PM
sand man's Avatar
why not both , 150+25
Quick Reply: Custom Intercooler Spray Bars.
