biggest shot w/ changing timing?
biggest shot w/out changing timing?
Hey guys,
I plan on installing a NE proton plus kit on my 2003 silverado 5.3.
The truck has a ASA cam and 3200 converter. Other than that all stock.
What is the biggest shot I can do without tuning? I will be running vp110 when I spray. It's my DD and I'll just spray on friday nights every once and awhile. 125, 150?
Also, I just put new plugs in the truck. Do I have to run different plugs? If I do, can I use those plugs for everyday driving? How long will they last?
Cant wait to spray
Thanks
Taylor
Cant wait to spray
Thanks
Taylor
I assume you have a custom tune. If so ask your tuner and that is your best answer.
I can tell you I had an aggressive mail order tune and blackbear told me that it wouldn't be a problem to run a 100 shot as long as I was running 110 in the tank while spraying. I never had an issue and ran 8-10 bottles in it.
Thanks
Former Vendor
I would start on 100hp and pull the plugs to see where the timing mark is, from that point you can determine if you can spray more. i wouldn't just throw 125-150 at it and hope for the best, start small and work your way up while looking at plugs.
I tried the Diablo tune on my 6.2 and it had massive amounts of very audible knock... So bad that I took the tune out and haven't put it back in.
No way I could have run nitrous on top of it...
Wow!!!! Thats strange... I have had no issues with the diablo tune and running the NOS, my AFR's are ok. No knock. Pulled my plugs and they look a tad rich, and a lottle hot. Those are my stock plugs though. I ordered cooler plugs. May have to adjust fuel some in the tune. I dont think I would feel comfortable using this setup over 150 hp.
If your going to do things, do them right, specially since its your daily driver.
If your going to run a 100 shot have your tuner put 24-25 degrees timing in it. If you wanna spray 150 shot have him put 22-23 degrees in it. A tr6 plug will be fine on a 100 shot, 150 shot run either a br6ef or br7ef plug. Tune it to 12.6-12.8 afr..
