Advice on installing nos
Going to be installing some nitrous on my 06 chevy 5.3 comp cam xr269hr, cai, exhaust with lts. Trans is slightly built. Larger pump, higher shift pressures, etc. what kind of wet shot can I put in with stock plugs and tune and what can I use with changing some stuff? Here's the kit: http://m.summitracing.com/parts/zex-82047
Former Vendor
The Proton Plus Drive by Dwire system would be a direct bolt on for you and will flow 150hp straight out of the box, and can flow up to 250hp with a few extra parts.
PROTON FLY BY WIRE NITROUS SYSTEM W/ 10LB BOTTLE
There is a lot wrong here. For one you don't want to run stock plugs with nitrous. You want to go a step colder and use copper tip plugs. No platinum or iridium. Also as mentioned you will want to get a real tune for nitrous. COntact Zippy and tell him you will be using nitrous so he can adjust it. Common rule is per 50 shot to pull timing.
ARC
57
02-21-2022 10:54 AM
sauldgold
07-23-2015 02:15 PM
