Newbie needs a Lift?
I have seen and worked on two nnbs running same size tires with leveling kit, if youre gonna do it, do it right and actually put a 4 or 6 inch lift on it, leveling kits on 4wd play hell on the cv axle angles, and the tires rubbed before even close to fully turned..... Most lift manufactures rec tire/wheel sizes on their lifts just find one that recommends something close to what you have which are roughly 35x12.5 18....
Registered User
Thanks for all the advice - good site to learn. can yall recommend a 4" that would work at the best price? The tires were close to free so coulndt pass up
Maybe i'm just super redneck But if you have the tires already mounted on the wheels I would go home put them on and see whats actually rubbing. Ifs its just some plastic inner fender junk or only the very edge of the bumper I would trim it myself.
But I like the stuffed big tire look.
Not so much the big lift with tires not even the wheel well look.
But if you really want a lift I would look into BDS there stuff is a little pricy but excellent quality! and it come swith add a leafs instead of blocks and all new shocks and yada yada.
