track run from sunday
Made some shock and caltrac adjustments, which didnt work out, but still had fun. 60fts went from 1.54-156s to 1.61-1.65. Heres a little vid of the 1.65 60ft run, ran 11.19 at 119, truck still on 93 pump gas and low timing, droping to 7.5 degrees in 3rd on this run. Best pass of the day was 11.13 at 120 with a 1.61, same situation. As soon as i get moved, meth it is. modded vette on progressive 150 shot, gto spares up front, slicks out back. He ran a 11.43 at 120 to my 11.19 at 119. I was working on my own plan and not reactions times, but he made it clear that that he beat me.
https://www.youtube.com/watch?v=Tdhy...ature=youtu.be
Thanks, Truck has been 11.02 at 121 with a 1.56. Basically I have qa1 drag R shocks up front, stocks with caltracs out back. For my 1.5 60fts I had front shocks set to 6 from full loose, and caltracs I had back off a bit so they wouldnt pre load while i was up on the converter building boost. I adjusted the fronts to full loose, and tried adjusting the caltracs to the 1/8 inch gap they recommend. i will be setting back to the way it was and maybe try 1 click looser, a little at a time. 3500 2 step at 9ish psi with a best of 1.541 60ft. Its so damn close 10s even with the lost power from timing, i figured Id try to gain a little in the 60ft.
Thats what he was, the truck did what it normally does, I just didnt worry about reaction times as much as he did, because thats not what I was there to do. But anyways, they celebrated pretty good over it. The truck actually out 60fted him, 8th mile, and 1/4 anyways. His reation time was almost a half second quicker lol.
Fk em....
More great consistent runs. I love seeing it... but i was hoping for meth lol. The title of the thread would have been more exciting if you were on meth already.
I think you're going to be blown away at the difference you see on the back half of the track. You'll be able to keep timing up near 15* (i forget how much boost exactly) for the whole pass and IAT's will be lower... I would be so bold to say I bet you see at least a 5 MPH increase.
AUTOT3K
01-30-2016 11:53 AM
