Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
Limited Slip POSI for GU4 8.5" read end 2WD. Any salvage yard direct swap ?
Old 11-25-2014, 11:17 AM
waid786's Avatar
Default Limited Slip POSI for GU4 8.5" read end 2WD. Any salvage yard direct swap ?
I have a GU4 8.5" rear end which came out of a 1998 S10 2WD.
My local yard has tons for GM stuff.
Is there any direct swap limited slip that will this rear end ?
Can someone please confirm that the pics below is the S10 with 8.5" rear end?
Thanks
Waid
Old 11-26-2014, 11:07 PM
Custm2500's Rude Friend
1FastBrick's Avatar
I believe the S10 is a 7.5 rear end.
Old 11-27-2014, 12:17 PM
68haywagon's Avatar
That top pic is an 8.5"
Old 12-15-2014, 11:44 AM
TXsilverado's Avatar
a few s10 pickups came with an 8.5. any v6 with a standard transmission and i think all zq8 packages. also most 4x4 s10 came with an 8.5 but it is a bit wider than a 2wd.
the picture above is an 8.5. you can tell by the ears on each side at the bottom. they are squared 90* instead of a moon shape.
Old 12-15-2014, 11:45 AM
fastjweb
08-15-2015 10:47 AM
So.cal Wrk Sled
07-26-2015 12:10 AM
Ammadien
07-22-2015 08:50 PM
ferrellrooster
07-13-2015 09:53 AM
Mark_k
07-09-2015 12:37 AM
Quick Reply: Limited Slip POSI for GU4 8.5" read end 2WD. Any salvage yard direct swap ?
