Limited Slip POSI for GU4 8.5" read end 2WD. Any salvage yard direct swap ?
I have a GU4 8.5" rear end which came out of a 1998 S10 2WD.
My local yard has tons for GM stuff.
Is there any direct swap limited slip that will this rear end ?
Can someone please confirm that the pics below is the S10 with 8.5" rear end?
Thanks
Waid
Thanks
Waid
a few s10 pickups came with an 8.5. any v6 with a standard transmission and i think all zq8 packages. also most 4x4 s10 came with an 8.5 but it is a bit wider than a 2wd.
the picture above is an 8.5. you can tell by the ears on each side at the bottom. they are squared 90* instead of a moon shape.
