Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
Header swap question
Old 01-15-2013, 05:23 PM
LsXblaze's Avatar
Default Header swap question
Hey guys I am planning on building up my 02 Blazer xtreme... lq4 block with ls3/l92 head. I have been trying to find out if there actually are headers specifically for D port heads??? also that would fit s10 frame. Has anyone heard of anything like this or will standard LSX header swaps work??
Old 01-29-2013, 11:20 AM
L$X$10's Avatar
Most that I know are running your standard LSx swap headers on a l92 head. BRP is probably going to be your best bet. I think they have a few different options to choose from. If you can find a set of used CPW headers(as Jared no longer makes them) they fit nicely inside the frame.
Old 01-29-2013, 01:28 PM
LsXblaze's Avatar
yeah thats what ive been thinking... brp headers look good. definitely going to need 1 3/4' at least
Old 01-30-2013, 09:24 PM
L$X$10's Avatar
1 3/4 should be fine for your application. here's one of many similar threads: https://ls1tech.com/forums/generatio...xperience.html
Old 01-30-2013, 09:52 PM
LsXblaze's Avatar
Thanks dude but im rethinking my plans... i got the itch real bad to get working on the swap so im thinking bout building up the block and using stock milled heads to bring the compression up.... but i still think 1 3/4 will still work well
Old 02-18-2013, 08:18 PM
Gonoma's Avatar
The in the frame long tubes from brp/hedman fit great...I bought them uncoated from jegs so that I could weld them together as one piece. Since they are designed in several pieces...I bolted them together and placed them inside the frame before putting the motor and transmission in as one piece (which you usually have to jack up the cab in order to do so) and was able to install them that way so I know they can be welded together and not have to worry with them leaking. I plan to get them coated afterwards so that's why I bought the uncoated ones...just a thought
Old 02-18-2013, 10:06 PM
LsXblaze's Avatar
okay awesome good to hear they work... ive been contemplating buying ones from racing innovations.... cheap price for decent quality...
Old 03-06-2013, 10:01 AM
FormerVendor
Stainless Works's Avatar
Stainless Works is currently in development of 1-7/8" headers for the LS Swap S-10, view the link: https://ls1tech.com/forums/sponsor-g...oup-buy-2.html
Give us a call or chime in with questions!
Old 03-17-2013, 02:49 PM
rpturbo's Avatar
The stainless works headers should be the ticket. Have to wait till they have them done, but their headers won't require you to run a special crossmember, and, there stainless!
Old 03-18-2013, 09:25 AM
FormerVendor
Development of these headers will be tough, the tolerance and clearance are tight, but we will have the best fitting S-10 LS Swap header available and YES they will be American Made 304L stainless.
GrooveCityZ71
08-31-2015 12:05 PM
creekrat
08-02-2015 01:27 AM
WICK3DxGATA
07-21-2015 06:59 PM
bsn1989
07-16-2015 08:20 AM
Quick Reply: Header swap question
