cammed 4.3 dyno #
#51
13 Second Truck Club
Ok I might sound like a dummy but the 2114 will need to be machined for the injectors correct? I was set on doing the marine swap when I make the change to boost. But it makes sense about the cast iron heat soaking. I'll want to be able to keep the incoming air as cool as possible.
For comparison.
2114 intake outfitted with fuel rails, injectors and tb adapter to carb
marine intake
#52
Yea I just looked it up lol. I'm def liking the 2114 setup. It'll be a while till I can do anything unfortunately. But I will be collecting parts for a cam swap. Thanks for the picks and the info man.
#53
my understanding of it so far is that it has to be drilled ang welded for the injector bungs. after that and the wiring it seems to be an almost direct bolt in
#54
Wiring isn't a big deal. What kind of rails do you use? I read a few places that they use summits rails and cut them down? If you could find the marine rails could they fit on the 2114?
#56
Ive heard of people using the summit rails and cutting them down.
You MAY be able to modify the marine rails, but Id imagine they would interfere with the throttle body.
RPM performance sells 4.3 fuel rails.
#57
rpm does sell those fuel lines dont they.... well see. ive told myself that the next thing i do to that truck is going to be a t56. then. and only then. will i do more to the motor.
#58
you HAVE to have springs (ls6) and a new timing cover. plus obviously the cam. everything past that is just insurance. i think i might would have gotten a custum grind. but its good enough.
Jay
#59
All this talk about doing v6s make me wonder about the Syclone........was it just a stock 4.3 with a turbo setup i dont now much about these trucks but there badass. Would it be hard to put that engine in there if there was any advantages?
