Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
5.3 Swap into S10
Old 02-16-2006, 05:58 PM
11 sec. Truck Mod
TIM Z's Avatar
yes, pics please!, also i found some good info on ls1 tech, there is a company called current performance that makes a direct PLUG and PLAY harness, no cutting or splicing,just un plug the factory harness and plug in the new one, he also sells programing if your interested, im probably going to use nelson performance cause i really like his tuning and hes always willing to help, but im stiil trying to find motor mounts for my zr-2, iguess the frame is a little diff from a reg 4x4, any body have some info please share-thanks!
Old 02-16-2006, 06:02 PM
11 sec. Truck Mod
TIM Z's Avatar
Originally Posted by jrodenali
Tim, your s-10 came with a 4l60E transmission, as long as the tranny from the 5.3L IS pre-03' they are the same 99%. In 03'they did some revisions to the now called 4L65E, but the big difference is the transfer case,the s-10 should have had a push-button case,while a fullsize could have had a floor actuated new venture case,or the push-button new process case,big difference,anything can be done,but an s-10 4x4 has alot of equipment stuffed in a small space,so it makes a difference, let me know a little more info. and I can probably help you out.....
i found out the full size 4l60e will bolt to the s-10 trans case, and i also read from several people that the CPI fuel pump i have will provide 60 psi, more than adequate for the 5.3, just a little more info for you guys, i know it will be a challenge, but i think some people make it sound harder than its going to be, just like any thing else, address 1 problem at a time and it will come together.
Old 03-04-2006, 09:33 AM
SweetS10V8's Avatar
Have you guys checked the book this guy made for the gen III swap?
Gen III Swap Guide
Bumpers
11
03-04-2024 05:55 PM
Chiphead
08-01-2015 04:43 PM
WICK3DxGATA
07-21-2015 06:59 PM
Go5.3tt06
07-20-2015 08:00 PM
06 4.8
07-15-2015 07:17 PM
Quick Reply: 5.3 Swap into S10
