07 classic to 5.3 nbs
I have the 4.3 auto and found a complete 5.3 2007 nbs that has d.o.d will this be a direct swap like the 2006 And any segestions will be helpful. Like motor mounts and the pedal my truck is drive by cable so where can I find the swap parts thanks
If it has dod it will not work without moving the knock sensors and using a lingefelter 58x 4x converter module to make the newer motor talk to your older pcm. You also have to lengthen the cam sensor harness wires and run them to the front timing cover
The 07.5 up motors that have DOD use a 58x crank sensor and 4x cam sensor
maxspeed05V
11-11-2015 04:20 PM
Alco
10-18-2015 08:23 PM
OHsixLS3
08-10-2015 07:19 PM
