Disk Brake Brackets for 15 Wheel Conversion
#43
Looks like the reply was deleted but someone asked: Just curious could these have the bolt pattern offset to bolt on to non disc brake trucks to put the caliper in the right spot?
Yes this is exactly what the new brackets do. Now the drum guys don't have to swap rear ends or anything to get disc brakes on their truck. Makes it a lot easier and you still retain the ability to run 15" wheels
#47
Don't know if I missed this somewhere but will these also work for the 14 bolt? Or just 10 bolts? obviously I know I will be swapping out the axles and all that but im interested on if they will bolt up to the 14 Bolt drum flange.
#49
Go to any of the parts stores in your area and ask for calipers for 91 C1500 2wd with the smaller caliper piston, brake pads, and rotors for a 4wd 91 K1500, ask for the banjo bolt for those particular calipers also.
