What pistons do I have?
I have a 2006 rcsb z71 with an LM7 and 706 heads. I found a set of LME cnc ported 243's milled .024 with BTR .660 platinum springs with titanium retainers. I'm trying to see what pistons I have without removing my current heads. Also wondering if these heads would be good for my application. Going to go on a turbo 5.3 and looking to swap heads from the 706's. My research time is very limited with a new son and long hours. I know there is a lot of knowledge on here and any input would be appreciated.
Custm2500's Rude Friend
Restricted
I've seen flat top Pistons in the 5.3 motors... I had a 06 and a 07 iron 5.3 that had flat tops.... And my 07 Tahoe 5.3 is factory flat top Pistons.... I believe they started using the flat tops in 5.3 around 2005ish maybe? Not sure if it was for all the motors or just H.O. Motors?
Restricted
Yes Gen VI applications had the flat tops. Those are 58X motors not the Gen3 24X motors.
Only 24x with flat tops was L33
No around 64-65cc on all 243/799 castings.
