Starter recommendations for 383 stroker
I have heard from somewhere that you have to go with a gear reduction starter for a 383 stroker or high torque starter. Is this true? Need help
Thanks
Thanks
Stock should be fine. The stock high tq starters have a ~1" copper tube spacer going between the solinoid and the rear of the started case. The spacer is there because the windings in the starter hare longer, thus the spacer is needed. Starters with the hot lug directly off the back of the solenoid are not the high tq.
Originally Posted by whitt1
I run a stock starter on my 403 with no problems.
starter for 383
The starter in question is going on a 383 stroker for a 1996 GMC Sierra. I don't know the compression ratio yet because I haven't talked it over with my engine builder/machinist. But thanks for all the useful info guys.
If it was me i'd just try the stock one and if it didn't work out worry about it then. I feel the stock one will do fine. I have a stock starter with 160k miles on it on my 95 1500 383ci with 10.1:1 compression. It does just fine.
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
