rockers
rockers
if i change to a 1.75 or 1.80 rocker on my int valves will i need
to change the push rod also ? i have a set of Comp 7.400 in
my engine now.
my engine now.
Are you using Comp adjustable rocker arms? You still have to double check your pushrod length but an adjustable rocker arm is not set up the same as a non-adjustable valve train.
KINGCYCLES
10-02-2015 10:21 AM
5.3lSilverado
09-20-2015 06:48 PM
