Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
Go Back   PerformanceTrucks.net Forums > GENERAL TRUCK PERFORMANCE, PROJECTS, & GROUP DISCUSSION...specifically > INTERNAL ENGINE MODIFICATIONS
Sign in using an external account
Register Forgot Password?
Register Albums FAQ Members Calendar Search Today's Posts Mark Forums Read VendorsGarageUsed CarsStore TSBs & Recalls
Welcome to PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 03-22-2011, 01:36 AM   #1
Trader Rating: 3
swift700's Avatar
Default Rear crank seal install advice needed- pics added
I'm putting my rear cover on tomorrow and have a question. I've read about problems using the new GM seal for forced induction and it seems that there have been a few problems with the seal leaking because it's not designed for much positive crankcase pressure. I've looked at the seal and it has a ribbed surface followed by a lip that points outwards. I've heard that some guys are installing these seals backwards to prevent leakage due to blowby pressure under boost.
For you guys with forced induction: which way do you have your new-style GM rear seals in? Have you had any leakage? Do you recommend another type of seal besides OEM?
The old style GM seal with the double lip is unavailable to buy but would probably be a good option. What sayeth the FI engine builders?
__________________
'00 Sierra ECSB, 9.9:1 forged 6.3 (383ci), Magnusen 1900 (2.8" pulley, 10psi), I.W. 8-rib, Holley 90mm, 228/236 551/551 116, Crane 1.8 rockers, Patriot 243's, 4L80E, Circle-D 2600, 4" ARH exhaust to go on in the spring
swift700 is offline   Reply With Quote
Old 03-22-2011, 01:52 AM   #2
Trader Rating: 31
Logs Look Good
Atomic's Avatar
__________________
99 z71 with some mods
Build Thread
Atomic is online now   Reply With Quote
Old 03-22-2011, 05:33 AM   #3
Trader Rating: 0
apex2112's Avatar
Not an expert but what about the rear seal from a LSA for a Cadillac CTS-V thats FI or a LS-9 ZR-1
apex2112 is offline   Reply With Quote
Old 03-22-2011, 09:57 AM   #4
Trader Rating: 3
swift700's Avatar
Not a bad idea. I think I'll look into that. Thanks.
__________________
Old 03-22-2011, 10:17 AM   #5
Trader Rating: 10
charcold-bowtie's Avatar
I had major leaks, so I installed it backwards and it fixed it. It will also depend on ring gaps and PCV system.
Seems to me there is no problems with installing it backwards in anycase, and stock boosted trucks probably dont have issues anyway due to the above reasons
charcold-bowtie is offline   Reply With Quote
Old 03-22-2011, 02:01 PM   #6
Trader Rating: 28
9 Second Club
code4's Avatar
I read all that too. I installed the new seal on my latest build & it hasn't leaked a drop. I read somewhere that the new seals are "thinner" & one must insure that they are fully seated.
Well they were correct, it sets deeper in the opening, not flush. I hope that makes sense. I did not install it backwards, I do not understand how that would work on the new seal I used.
__________________
"There are two types of racers: cheaters...and losers." - Smokey Yunick
[SIGPIC][/SIGPIC]
If it ain't broke, I can't afford it....
code4 is offline   Reply With Quote
Old 03-22-2011, 02:43 PM   #7
Trader Rating: 3
swift700's Avatar
Here are some pictures of the new GM seal for clarification. As you can see, there are two sealing surfaces. For reference, the yellow side of the cover goes towards the outside of the engine and the silver is the inside. There are two sealing surfaces- one is a ribbed rounded surface and the other is a lip seal. Neither look as though they would seal much pressure into the engine when installed as per the manual.
From the outside looking in:
The lip seal:
The rounded ribbed seal:
From the engine side looking out:
The rounded seal and lip seal both taper towards the outside of the engine.
It doesn't look as though this would hold much pressure in. You can see that if the seal were installed backwards that both surfaces would act to keep pressure inside the engine. Pressure would expand the lip seal towards the crank surface, tightening it up.
One disadvantage with installing it backwards would be that it would not seal against debris getting in very well. Not good for an off-road rig.
Old 03-22-2011, 10:54 PM   #8
Trader Rating: 19
PT's Slowest Truck
budhayes3's Avatar
I've heard about the backward install trick also, and that the seal is actually marked "this side out" or something like that, and to disregard that recommendation and actually install it "that side in" lol.
__________________
Billy
[SIGPIC][/SIGPIC]
[URL=http://www.cardomain.com/memberpage/648999]My CarDomain Page[/URL]
[FONT=Garamond]99 5.3 Z71 RC/SB - [COLOR="Blue"]FLT Level7 65E[/COLOR], [COLOR="Purple"]Circle-D Billet 258mm 2B Multi-Disc[/COLOR], Comp 206/212 515/520 114, LS6 Springs, Harland Sharp 1.7's, [COLOR="Red"]BlackBear 02 PCM[/COLOR], 02 Injectors, 160* stat, 05 E-fans, Nelson Harness, Volant CAI w/ Ram Air, StainlessWorks Headers and !Catted! Y-Pipe, DMH 3" E-Cutout, 18" Magnaflow dumped over axle, 3.73 G80, Dropped on Gibbs 20's [B]**H/C LQ9, 4.10's, and TruTrac eventually**[/B] [/FONT]
budhayes3 is offline   Reply With Quote
Old 03-22-2011, 11:06 PM   #9
Trader Rating: 9
Swerve7rpm2000's Avatar
i put mine on the correct way and just made sure i have plenty of breathers to let most of the crank case pressure out, havent had any problems yet.... Drivers side to a canister, pass side with the filter that goes where your oil cap normally would, ls6 valley cover with a little breather on it
__________________
1995 RCSB Chevy 408, 9:1 Cr, Callies Crank/Rods, Diamond Pistons, TFS 225's, Garret 91mm, AMS1000, Alkycontrol, KB Hot Parts, Custom Intercooler & Piping, Ladder Bar, drag springs & QA1's, Full Manual Th400 & T-Brake, Circle D, Full Spool 3.42, Champion Forged Wheels, 5" DP w/ Magnaflow, 10 Point Chromeoly Cage
http://Build Thread: http://performa...d.php?t=469809
Best Passes: http://www.youtube.com/watch?v=s7Uir...ure=plpp_video
Swerve7rpm2000 is offline   Reply With Quote
Old 03-22-2011, 11:47 PM   #10
Trader Rating: 94
Baltimore Whore
Mangled03gmc's Avatar
Send a message via AIM to Mangled03gmc
Also have heard the rev trick on that seal... The vent in the valley cover is new to me however.. I think that will be a next mod I do, to insure the case is venting enough.. There is plenty of ways you can vent the case, even buy running lines from the covers to the exhaust... I am venting the pass side into the air, still have the pcv on the driver side hooked up.. Thus far no issues..
__________________
JOHN
RIP brother
Artificial Intelligence is no match for natural stupidity.... You can't fix stupid
*Approved *** Seller*
Mangled03gmc is offline   Reply With Quote
PerformanceTrucks
Ford F150
Paid Advertisement
Tags
300dt, back, backwards, chevy, correct, crank, crankshaft, install, installed, leaking, lip, location, rear, seal, trucks
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
PerformanceTrucks.net and InternetBrands, Inc. are not affiliated with the Ford Motor Company
