New melling oil pump install now no pressure
Old 02-25-2017, 10:46 PM
fillpot's Avatar
Default New melling oil pump install now no pressure
Guy's just installed a melling high volume oil pump on my 2000 5.3, just started it up for a sec and no oil pressure, everything went pretty smooth I thought, new green o-ring, did drop the pan, shimmed the pump .002 and .003, the only thing I can think of is maybe a screwed up the o-ring on the install, but I thought it was fine, the reason for replacing the pump was sometimes the truck would develop a lifter tick from time to time ( which has been discussed on here) other than that the pressure was good, the only other thing is maybe the shimming? just looking for a little insight. THANKS!
Old 02-25-2017, 10:48 PM
FFDP's Avatar
Tried pulling the fuel pump relay and just cranking it for a while to see if it will build pressure?
Old 02-25-2017, 10:59 PM
fillpot's Avatar
No I haven't but I will. THANKS!
Old 02-26-2017, 12:15 AM
Wolftrk99's Avatar
Are you going by the guage or an oil pressure tester? If you're going by the guage you have to give it time to come up, especially with a new dry pump. As FFDP, said try priming the system and see if it comes up quicker!
Old 02-26-2017, 07:26 AM
fillpot's Avatar
That's what I'm going to try this morning, maybe I'll get lucky. THANKS!
Old 02-26-2017, 09:21 AM
03sierraslt's Avatar
Keep us posted, hope it just needs a good prime.
Old 02-26-2017, 04:48 PM
fillpot's Avatar
No luck with the priming guy's, just going to tear it back down, you would think though you should have some pressure? THANKS!
Old 02-26-2017, 05:10 PM
Sounds like you may have a oring issue.
Old 03-01-2017, 03:15 PM
Ken in AZ's Avatar
I just saw a similar issue from a local shop that pulled the pump and the spacer plates for a double roller were installed incorrectly so check those if you have a double roller.
If that was the only thing you changed then definitely o-ring, but don't forget to check the front plug too
Also - I packed my pump with petroleum jelly to help with priming - instant oil pressure almost
Old 03-01-2017, 10:10 PM
fillpot's Avatar
Sorry guy's been out of town a few day's, I found the problem and it was my screw up, the flange that's on the pickup tube that bolts to the pump is not flush, when I took it apart it was like this as well, dumb *** me put it back that way, stupid, just wasn't thinking and this is the first one I've done ( well done a camshaft swap on my LS2 69 Camaro)So got it tore down and ordered a new melling pickup tube, something just isn't quite right about the old one, going to start putting it back together tomorrow, I'll post back up. THANKS!
