My LQ4 427 build
#21
The only thing I would change is going from spring over to spring under, or doing a short course style 4 link. Axle wrap is a beech and I'd hate to see it cause any damage to the rest of the truck if you break a leaf or u-bolt. I've seen it happen to guys with a fraction of the hp you have on smaller tires.
#22
#24
Keep you all posted!
#25
8 Second Truck Club
I originally wanted to do a 4.125" stroke crank in my current motor and in the beginning, my engine guy was all in too. For the most part I just let my engine guy do what he wants as I've never been able to destroy anything he's put together. I pretty much drop off a block and cash, tell him how it is going to be used and he calls when it's done. I guess after some thought he changed his mind (didn't even ask him why) and I ended up with a 4" crank.
Anyway, I remember posting on the bullet about wanting to do the 4.030"x4.125" combo in an iron 6.0 block. I didn't ask if was an issue, I just wanted comments from those who had done it and I pretty much got put on blast as everyone told me what a stupid idea that was with most citing durability issues and oil consumption. I ignored it for the most part as the people posting that **** either A. have never done it and like to just regurgitate stupid **** they read to sound like pros or B. refused to recognize the fact that I could care less about durability as the engine would not see mileage. I think I've put 10 miles on it so far (about 40 1/4 hits) and it's already been back in for a freshen up. I have a tendency to destroy head gaskets for some reason lol.
#27
Anything over a 4" stroke got a bad name back in the day because of poor piston design causing the problems you mentioned. That being said - I'm pretty sure Brian Tooley has had a 427 lq9 stroker with the 4.100" stroke run reliable and make decent power.
#30
lol and actually I thought that was pretty high. I went with a 10cc dished piston because I thought I'd go with a blower soon and it was the least amount of dish available. Flat top pistons would have put my compression ratio through the roof and too much for pump gas. Being pump gas friendly was always a concern too.
I felt that 11.4 was a good balance for NA power and later getting the heads done with the combustion chambers cnc'd so I'd end up in the high 10's for compression making for a decent street blower combo with E85.
Once I get my Ported L92 intake sorted out I feel the power levels and mid range torque should make the truck pretty fun. The fuel rails I just ordered from Holley are apparently made for their "sniper" manifold and don't work on the factory manifold. So now I'm gonna have to make a set of LS3 rails fit.
That and I'm having my torque converter re-stalled higher and changing the shift firmness in my valve body so it should make my truck a lot more fun to drive.
I'm still thinking about the BTR cam - it'd probably still make the same power but would be nicer to the valvetrain.
