LQ9 Build...
Old 01-14-2015, 09:38 PM
sam72104's Avatar
Default LQ9 Build...
LQ9 Build...
2006 Silverado 4400 pounds with me in it.
3600 stall 4.11 gears
I want to bore it .30 suggestions on pistons
cam? going custom grind. suggestions will help
crank? suggestions would be nice.
said it was knocking when pulled?
243 heads milled .015
truck is a show/weekend warrior want to go nasty as possible but keep it weeknend drivable! GO!!!
Old 01-14-2015, 09:42 PM
8 Second Truck Club
natejk's Avatar
N/A,Forced Induction,N2O?
Old 01-15-2015, 12:33 PM
53bowtie's Avatar
What part of Arkansas are you from? I am orignally from the Fort Smith area......
If it was knocking before pulled you need to at least pull the pain and determine which bearing(s) are the culprit. Hopefully its a rod bearing but in my case it was a main bearing and I had to scrap the block. If the stock crank is not hurt then I would just rock that unless your planning a 1000hp build.
Old 01-15-2015, 10:21 PM
sam72104's Avatar
I haven't decided. Prolly NA for awhile but will have boost or spray one day. And I'm from malvern/hot springs area.
I also need to know what pistons to run! Input would help!
Old 01-16-2015, 12:18 PM
53bowtie's Avatar
Its really impossible to tell you what pistons to run without knowing the future setup along with a target compression. With milled 243's your obviously looking to build a higher compression setup so you will also want to take into account your cam selection as well to make sure you dont have PTV issues.
I would pick a target compression, find pistions that will get that compression, then find a cam that will not have PTV issues. If you plan on boost or spary then forged would be best for insurance down the road.
My wife and I really like the Hot Springs area. That is actually one of our favorite places to visit because its close enough to Dallas to make a weekend trip out of it.
Old 01-25-2015, 08:33 PM
sam72104's Avatar
What's everyone's thoughts on this kit?
http://m.ebay.com/itm/361178161869?nav=SEARCH
Old 01-27-2015, 11:27 AM
procelll's Avatar
I know that company's rebuild kit for 4.7 dodge is good. We've used it to rebuild 2 different trucks. I couldn't tell you on a ls. I'm from mena by the way.
gmcyukon
10-05-2015 06:20 AM
Wolftrk99
10-02-2015 08:17 AM
LSX-81-SIERRA
10-02-2015 07:05 AM
The_W
10-01-2015 02:35 PM
Quick Reply: LQ9 Build...
