Lifters, help
Lifters, help
I'm having trouble choosing a set of lifters for my engine. I'm going to be shifting around 7,000-7,500 rpm, I want to stay away from the ls7 lifters. Any help is appreciated thank you.
Comp short travels are decent and there are a few other short travel lifters out there that are for higher rpm use and still retain the ease of preload adjustment. On my Comps they call for 1/4 turn but I went a half turn because they were noisey at 1/4. Not sure what that relates to as far as preload .0XX" Best bet would be to go full solid but then you have to set lash and continually maintenance.
