HOW TO change valve springs on chev 5.3 ??? - PerformanceTrucks.net Forums
Thread Tools Search this Thread
Old 03-09-2010, 09:51 PM   #1
Default HOW TO change valve springs on chev 5.3 ???
I just bought some PAC 1218's for my CHEVY 5.3. What is the easiest and cheapest way to change valve springs without removing the heads??
thanks gb
gblauf is offline   Reply With Quote
Old 03-09-2010, 09:54 PM   #2
2000chevysilverado's Avatar
First you need a valve spring tool 10 bucks at oriellys then you need a air atachment for the spark plug 15 bucks at oriellys, its easy to do and simple just time consuming you will need new valve cover gaskets those are cheap, you dont need to remove the heads at all to put new valve springs in
2000chevysilverado is offline   Reply With Quote
Old 03-09-2010, 09:55 PM   #3
PT's Slowest Truck
budhayes3's Avatar
Easiest way IMO...use compressed air and a fitting in the spark plug hole to hold the valves up and get the Crane valvespring tool that does 2 springs at a time and compresses them perfectly and evenly. The tool is a little pricey but worth every penny for how well it works.
If you don't have access to an air compressor, you can feed rope in through the spark plug hole then run the piston up and the rope will hold the valves up.
I use a magnet to remove the keepers (valve locks), then put grease on them to hold them to the valve stem as I release the pressure on the valve spring(s)
budhayes3 is offline   Reply With Quote
Old 03-09-2010, 09:56 PM   #4
few differnet ways buddy,
1. they make a tool that screws into the spark plug hole and connects to a air line, and keeps the cylinder pressurized so the valves wont fall, and do one cylinder at a time.
2. make sure the piston your swapping the springs on is at TDC, and the valves wont be able to fall.
get a valve spring compressor, and i use a small 'pin magnet' to catch the keepers
james8997 is offline   Reply With Quote
Old 03-09-2010, 09:57 PM   #5
yall beat me to it, damn i type slow
Old 03-09-2010, 10:39 PM   #6
i have the lingenfelter tool, cost 80 bucks, but ive done 4 cam swaps with it!!! and of course compressorwith air tool
http://www.lingenfelter.com/mm5/merc...Category_Code=
06tx4.8 is offline   Reply With Quote
Old 03-09-2010, 10:43 PM   #7
Where's the Beef?
viciousknid's Avatar
next question.
viciousknid is offline   Reply With Quote
Old 03-09-2010, 11:04 PM   #8
Here you go: http://www.ls1howto.com/index.php?article=23
This is for an LS1, but the method is the same, and easier since there is more room to work on these trucks. I'll be swapping in some springs in a couple weeks, but I'm going to be taking the heads off to swap the lifters too.
Ferocity02 is offline   Reply With Quote
Old 03-10-2010, 01:10 AM   #9
Mrgoodwrench3's Avatar
All of these tools are easily available at many sources. SEARS, Harbor Freight, Snap On, just PLEASE PLEASE DO NOT use rope into the cylinder.
Mrgoodwrench3 is offline   Reply With Quote
Old 03-10-2010, 11:16 AM   #10
PT's Slowest Truck
budhayes3's Avatar
Quote:
Why not? Guys have been doing it for years and years...just be sure to leave some hanging out so you don't lose it in the cylinder, and make sure that the rope doesn't fray easily...
It's not the preferred method, but it works if you don't have access to an air compressor...
Thread Thread Starter Forum Replies Last Post
Turbo 2007 NNBS Silverado RCSB chopperloco Trucks and SUV Classifieds 15 07-10-2016 10:45 PM
wtb comp 265 cam bizle WTB (Wanted To Buy) 0 07-22-2015 07:31 PM
Need input, 350-400hp 5.7l vortec build 4B11T INTERNAL ENGINE MODIFICATIONS 2 07-13-2015 03:48 PM
Lets talk Valve Springs. Experts please come in. 07NBSChevy GM Engine & Exhaust Performance 20 07-08-2015 07:27 PM
Lq4 valve retainer part number needed Mzay GM Engine & Exhaust Performance 2 07-06-2015 11:05 PM
Tags
2000, 53, 53l, arms, change, chevy, freight, harbor, head, lifter, lifters, removal, removing, replace, rocker, spring, valve, valves
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
