Help.. anyway to recover the 5.3??
Old 01-29-2015, 01:17 PM
Sexyrado327's Avatar
Default Help.. anyway to recover the 5.3??
Is there anyway to recover a bolt that gets dropped inside the block?
Was removing the knock sensor valley cover and a bolt from the side slid and went inside through the little hole were you can see the cam.
Is dropping the oil pan the only way to get it or is it screwed if I dont find it when I do drop the pan?
Old 01-29-2015, 01:19 PM
Any info would be great thanks
Old 01-29-2015, 02:40 PM
07bluelbz's Avatar
Could be sitting on too of the cam still. Try running a magnet down in the hole.
Old 01-29-2015, 08:46 PM
Already tried the magnet no luck
Old 01-29-2015, 09:23 PM
GMCtrk's Avatar
Yep, sounds like you need to pull the oil pan and windage tray.
Old 01-30-2015, 02:54 PM
High on diesel fumes
thunder550's Avatar
There's a small chance you could get lucky and it'll come out when you drain the oil. I doubt it, but it's good to have hopes and dreams right?
Old 01-30-2015, 11:22 PM
Gadgetized's Avatar
How big is the bolt that fell? Will it come out the drain plug hole? I would drain the oil and stick a long magnet in the pan. If you don't get it, you might try to blow compressed air down the hole where it fell to make sure it makes its way to the bottom.
If you need to turn the engine over to make it fall be careful to not foce it against something. The best way to do this would be to remove the spark plugs, and back off the rocker arms so there is very little resistance.
Old 01-31-2015, 08:58 AM
Thanks for the replies guys, the bolt that fell is a bolt from the knock sensor valley cover, went to pry it up the cover because it was stuck and popped to hard and down went the bolt..
Though about turning the crank from the lower pulley and then using a magnet from there, dropping the pan is the last thing i want to do since my trucks frame is about 3-4 inches off the ground, currently sitting on two cynder blocks and i could barely even slide my head in without having metal 1-2 inches from my face!
Old 01-31-2015, 12:03 PM
Gadgetized's Avatar
I would remove the oil level sensor on the passenger side of the pan near the starter. If you can snag it with a magnet it might fit through there. I think the hardest part will be to get it past the windage tray.
Old 01-31-2015, 02:34 PM
Thanks for the input, i did see the sensor on the side will try that for sure before pulling the pan.
I also searched on here and found that the bolt could be left in the pan?
Wont get sucked in by the oil pump and will just chill in the bottom without causing harm? Is there any thruth to this.?
Quick Reply: Help.. anyway to recover the 5.3??
