Head bolt choice with tvs 9psi
Old 03-04-2015, 03:06 PM
Matt331's Avatar
Default Head bolt choice with tvs 9psi
Getting ready next weekend to do my cam/dod/Afm delete and looking for advice on head bolts. New gm which I already have or arp.
Thx
Old 03-04-2015, 03:56 PM
vettelovralexand's Avatar
At 9 psi either is likely fine. But I would do ARP so that you have margin if you turn it up and can reuse them if you need to.
Old 03-04-2015, 04:40 PM
Preston129's Avatar
Since you already have them, I'd use the GM bolts.
Old 03-04-2015, 05:01 PM
92SS Wagon's Avatar
I'd go ARP also. I read an article today that said the GM bolts should never be reused and the single biggest failure on a LS motor is reusing bolts. FYI
post some pics when you do it if you would and an idea of how long it takes you if you would. I cant wait to start mine thanks.
Old 03-04-2015, 05:29 PM
03sierraslt's Avatar
He said he already has NEW bolts fyi.
Old 03-04-2015, 08:35 PM
92SS Wagon's Avatar
Yeap I read that part
Old 03-04-2015, 08:51 PM
Formerly ScreamingL
George C....'s Avatar
something you may also want to think about is you may have VVT on the motor if its a LC9 5.3
my 2010 had it
for the insurance ARP are worth it especially if you ever plan to crank it up
Old 03-04-2015, 09:14 PM
Matt331's Avatar
my 2010 had it
Yes I'm deleting Vvt also. Thx for reply
Old 03-04-2015, 09:17 PM
Formerly ScreamingL
if using a 3 bolt cam you will need a sprocket from a 06 vette to use a 3 bolt cam in that pcm
Old 03-04-2015, 10:20 PM
GREENSIERRA's Avatar
Just get the ARPs, its only money at this point:p
Quick Reply: Head bolt choice with tvs 9psi
