cam
Old 08-14-2014, 11:48 PM
turboal1's Avatar
Default cam
is there usually enough PTV clearance in a stock 5.3 to run a .600
lift cam with a short dur. ? 224 deg. dished pistons. 799 heads
this is a running motor in truck that i want to put the cam in.
Old 08-16-2014, 08:03 AM
GREENSIERRA's Avatar
I ran a 223 226 610 605 110+4 cam in my old L33 with flat tops and 799s with no problems at all
Old 08-19-2014, 03:55 PM
diRty?biRd's Avatar
219/223 607/610 112+2 in a LC9 with flat tops and 799's
Old 08-19-2014, 08:51 PM
craigsix's Avatar
i think its safer to run the cam stright up.
Old 08-20-2014, 09:48 AM
turboal1's Avatar
Default clearence
the cam has a 105 int C/L with 114 lobe sep and it's a VVT cam
forgot to put that info in, sorry
Old 08-20-2014, 07:39 PM
craigsix's Avatar
i think thats too much lift for a vvt cam i was checking that out when i first got my truck a couple years ago. one of the phaser limiters is safer i think the older version. check with tsp im thinkin 570 max on the 5.3 with flat tops and #799s. let me know thats probably in my future to igot the 1.8 yella terras. i was gonna get a cusyom ground vvt from sdpc with about 530 lift to ba safe. rite now i got the dod/vvt 500 lift comp cam with my 1.8s its about 536 lift.
Old 08-21-2014, 11:28 AM
turboal1's Avatar
Default clearence
I have .556/.568 right now, going to put the 1.8 rockers on it.
moving it to .589/.602
Old 08-21-2014, 01:21 PM
craigsix's Avatar
guess youl find out at about 6200 rpms.
2500ZL1
01-25-2016 06:30 AM
lawhitediamante
08-12-2015 12:14 PM
steves86ta
07-28-2015 10:21 AM
WICK3DxGATA
07-21-2015 06:59 PM
projectnightcrawler
07-19-2015 11:30 PM
Quick Reply: cam
