Best Rings for 6.0 with nitrous
Buddy of mine is rebuilding his 6.0 and was wondering what rings everyone is using.
Pretty much stock internals with Lunati cam in the area of 221/218 and head work. Made a little over 400 at the wheels.
Neal
Neal
Total Seal makes a nice ring set, but in reality I've seen the factory rings take some pretty good abuse and hold up fine. If everything is apart you might consider opening the ring gaps up for use with a big power adder.
Aaron, how much do you recommend opening them up? This motor dyno'ed a little over 400 HP (RWHP) with tuning and he is working his way up to a 300 HP shot.
Neal
Neal
Totalseal CS AP ring package if your going to be replacing rings, cheap insurance. They are a bit more forgiving on the cylinders than say a Hellfire. For gap, follow Totalseals spec chart and you will be fine.
Nitrous 150HP-350HP Gas, Alky, E85 Bore X .0075" Bore x .0065" Min .015"
