Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
Go Back   PerformanceTrucks.net Forums > GENERAL TRUCK PERFORMANCE, PROJECTS, & GROUP DISCUSSION...specifically > INTERNAL ENGINE MODIFICATIONS
Sign in using an external account
Register Forgot Password?
Register Albums FAQ Members Calendar Search Today's Posts Mark Forums Read VendorsGarageUsed CarsStore TSBs & Recalls
Welcome to PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 01-23-2012, 08:37 PM   #1
Trader Rating: 3
blue0453's Avatar
Default 99 5.3 engine question
Ok you gear heads, help me out here. My neighbor has a 99 rcsb 4x4 with a 5.3. He says in the morning that the truck has no oil pressure at idle till the truck warms up. He has to keep his foot on the gas for it to have pressure. My questions are #1. He called the local dealership here and they said that his vin is saying that he has some special bolt pattern 5.3 that was used in the early years??? Can he just get any 99-07 5.3 and swap out, I have never heard of this bolt pattern thing execept in the headbolts being a little different around 03/04. #2, if we decide to just swap the pump how difficult is it to drop the pan on the four wheel drive models vs the 2wds. Thanks in advance Nick....
__________________
04 rcsb silverado 5.3, kbracing t-76, 80e, yank3200, transgo, tr220, comp 675s, 72lbrs, walbro/racetronix hotwire, snow meth, 11psi, nelson tuned
06 tbss. Stock for now....
blue0453 is offline   Reply With Quote
Old 01-23-2012, 08:42 PM   #2
Trader Rating: 11
11 sec. Truck Mod
TIM Z's Avatar
You just need to loosen and almost unscrew all the oil pan bolts, then take off the front accessories/water pump/timing cover . Then you will be able to change the oil pump, the hardest part is getting the new oring / pickup tube inserted. But it can be done.
The oil pumps generally dont wear out, they are gear driven, i bet its the older style faulty o ring isnt sealing correctly. I believe the new o ring is green.
I havent heard of a diff. bolt pattern for the 99 5.3
Good time for a cam swap while you are there!
__________________
2000 ECSB Z71 LT
LQ4 . TVS 1900 . 2barSD Dyno/Street Tuned by TJ
Comp Cam. AlkyControl Meth .Long tubes. LC32 8Rib
4L80E . PI 2600 triple disc
11.6@114 ( 12psi no meth) new times coming .
2007 CCSB LT3 2500HD 4x4 DURAMAX LBZSOLD
EFI LIVE DSP5. MERCHANT Built 6SP ALLISON-PI race Verter. 6" T.C. Lift-
2005 Tahoe Z71/ 2004 2500 Express 6.0/80E 232k!
Big thanks to Pat(03sierraslt),Mark, and TJ @ BEI
TIM Z is offline   Reply With Quote
Old 01-23-2012, 09:05 PM   #3
Trader Rating: 3
blue0453's Avatar
Thanks Tim... this is his work truck that he bought new and has pulled a trailor about every day for the last 12 years. It has over 300k on the motor so I doubt that he is gonna be intrested in a cam swap, lol...So how much will the pan drop, I thought the crossmember had to be dropped to do this job?
__________________
Old 01-24-2012, 01:50 PM   #4
Trader Rating: 11
11 sec. Truck Mod
TIM Z's Avatar
Man for the money you will have in parts i would just find a low mile 5.3 and swap in. You'll be further ahead, they can be had for 5-600$.
__________________
2000 ECSB Z71 LT
Old 01-24-2012, 03:26 PM   #5
Trader Rating: 10
LS1Tech Sponsor
hellbents10's Avatar
Wild thing here is we have had two oil filters fail in the last 2 months with two different trucks. One was a Wix and one was a delco in two different trucks. One was a 2000 yukon and the other was a 2000 truck. Same type of problem too, could have sworn the press. relief stuck.
Changed the filter on both and problem was gone. One was starting to hammer a bit on the top end even!
__________________
TJ, tuner for Dave Adkins LSX 63' Impala, 6.94@204.
Fastest non-intecooled corn feed turbo engine 6.95@195.
[SIGPIC][/SIGPIC]
www.bakerengineeringinc.com
616-837-8975
hellbents10 is offline   Reply With Quote
Old 01-24-2012, 04:46 PM   #6
Trader Rating: 0
01silvy's Avatar
If yall are sure the engine in it now is in good condition and the bearings aint gone then i would drop oil pan clean it out good. Remove all front engine items and balancer pull the front timing cover and replace oil pump and pickup tube o-ring, and put a new timing set on it.. Just take your time with everything.. Does the engine use oil or smoke now?
01silvy is offline   Reply With Quote
Old 01-24-2012, 04:55 PM   #7
Trader Rating: 11
11 sec. Truck Mod
TIM Z's Avatar
Wow man thats crazy.
I could understand if it was a crappy Fram filter, but i hate hearing it was a wix and a delco, the only two kinds of filters i run!!
Good point though for the O.P. TJ, good outta the box thinking !!
__________________
2000 ECSB Z71 LT
PerformanceTrucks
Ford F150
Paid Advertisement
Tags
2000, 53, 99, bolt, cam, drive, dyno, engine, motor, oil, patern, pickup, ring, silverado, wheel
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
PerformanceTrucks.net and InternetBrands, Inc. are not affiliated with the Ford Motor Company
