5.3 stroker
If there is anything we can do to help let us know. We have Gen 4 58X 383 aluminum stroker shortblocks in stock with free shipping and free Joe Gibbs break-in oil for $2695.00.
LS 383CI Short Block -15cc Dish With Free Shipping
I don't run the website, but what is blackout? Or did you mean block? We carry cylinder heads from most major manufacturers such as Trick Flow, AFR, PRC, Brodix, GM. All depends on your budget and goals.
A great bang for the buck cylinder head would be the PRC AS-Cast 225 cathedral port aftermarket castings. At 1799.99 assembled with a dual PAC Springs they are hard to beat. In N/A applications these cylinder heads have produced over 500rwhp on LS2 stock bottom end applications. They have a thicker deck and laid over valve angle for increased deck strength and improved piston to valve clearance. They can be had with a 68cc chamber which would put compression on this particular setup right at 9.43:1.
