5.3 pcv ?
Old 02-27-2010, 07:00 AM
Doobie's Avatar
My 03' had a baffle under the rocker cover which looked and worked pretty effectively. I removed the baffle and and plugged the PCV hole and installed an LS6 valley cover for my Radix install. My new rockers also dictated that I remove the PCV baffle as there was an interference issue. I had no problems with either set up. The LS6 valley breather is a much cleaner looking install and is a fairly inexpensive mod worth doing if you have your intake manifold off or plan on removing in the future.
eallanboggs's Avatar
Is there a tutorial on how the LS6 PCV system works? I'd like to read up on that. Does it vent the crankcase out of the valley cover rather than than Bank 1 pushrod holes? If that's the case you could draw fresh air in on BOTH banks and vent out through the common valley cover and then back into the intake. Now all you need is a catch can.
Old 02-27-2010, 04:03 PM
PT's Slowest Truck
budhayes3's Avatar
Originally Posted by eallanboggs
They went to what they call "fixed venturi" PCV which if you thing about the way the PCV system is designed to work the PCV valve can NOT be fixed. It needs to be variable and two way to work properly. If they put extra baffles in there I guess that would turn the area under Bank 1 rocker cover into a big catch can of sorts. I went to Harbor Freight and got a OIL/WATER separator for an air compressor for $8 and two hose barbs at $2 each. An other $2 for 3 feet of 3/8" hose and you've got a catch can for under $20. After seeing what you find in your catch can you'll wish you had one on there from day one. In areas of high humidity you'll also find water in your catch can(or water and oil mixed-MILKY) which is the result of condensation in your oil pan after the engine goes through cold soak.
I ran pretty much the same set up before I got my AMW catch can, and the only problem with the air/water separator is that it quickly became saturated and oil was bypassing the filter and being sucked right into the intake. I was running it for a few weeks when I noticed that the level in the reservoir stopped rising, when I pulled the hose off of the intake (which was a new dry hose when I installed the "catch can"), it was full of oil. Might want to check yours out just for poops and giggles.
Let me know if you do find a tutorial on the LS6 PCV system as I'm very interested to know how it works also, thanks in advance
Old 02-27-2010, 05:59 PM
Big Port Jimmy 6's Avatar
Some info here
http://www.ls1howto.com/index.php?article=18
Jay
Old 02-27-2010, 06:13 PM
PT's Slowest Truck
budhayes3's Avatar
I've been wanting to do the LS6 conversion just for the aesthetics of it, but I need the cash to get the truck back on the road first, and I do have a nice catch can....(to the right of the picture secured under the cowl)
Old 10-25-2012, 12:50 PM
BIGHAL's Avatar
Your truck isn't BOOSTED! Mine is. I need a way to get the Vapors out During Boost
Old 10-25-2012, 01:29 PM
nonnieselman's Avatar
Did you search for PCV or Catch Can?
just wondering cause this is quite an old thread.
I run the stock pcv with a filter/seperator from my passenger valve cover to the Airbox pre turbo.
lucas287
31
01-12-2021 06:18 AM
pewter00
09-14-2015 09:17 PM
11MPG
09-08-2015 04:52 AM
pewter00
09-07-2015 10:14 PM
2004gibbstruck
09-07-2015 06:05 PM
Quick Reply: 5.3 pcv ?
