408 towing build - PerformanceTrucks.net Forums
408 towing build
LinkBack Thread Tools Search this Thread
Old 12-22-2011, 04:44 AM   #1
Default 408 towing build
Im thinking of doing a 408 stroker build geared towards towing in my 2000 2500. It would use TEA ported 317's, a rotating assembly from texas speed, EPS truck torque 2 cam, and long tubes. I think I may also need a larger throttle body, such as the nick williams 92mm unit. Will this tb fit my stock intake? I feel a FAST setup might be overkill, considering this engine will seldom operate above 5500.
TA63 is offline   Reply With Quote
Old 12-22-2011, 07:29 AM   #2
SweetS10V8's Avatar
The cool thing about the FAST is that it makes power accross the board, not only at high RPM.
SweetS10V8 is offline   Reply With Quote
Old 12-22-2011, 08:55 AM   #3
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Do you have some sort of alert set up when anything about a FAST intake is posted? It seems like I always see you in them
1slow01Z71 is offline   Reply With Quote
Old 12-22-2011, 12:59 PM   #4
Believe me, its not that I don't want the FAST intake, its a cash thing.
Old 12-22-2011, 01:02 PM   #5
ltr450ryder's Avatar
Ya I just bought one for my my build not cheap at all lol
ltr450ryder is offline   Reply With Quote
Old 12-22-2011, 07:30 PM   #6
SweetS10V8's Avatar
Quote:
I have done a lot of testing on them, and they are really worth the money.
Ive tested the edelbrocks as well all of the OEM LS car/truck intakes, so i understand intake more than most.
I also had a bad expereince with an engine that was a terrible combination, and it sucked. I try to keep people out of the same situation as I was in. (First engine was 350 SBC, 882 heads, Single plane intake, 750 carb, 8.5:1 compression, 254/264 .525 lift solid flat tappet cam)
Old 12-22-2011, 08:05 PM   #7
Ouch, I bet power was nonexistant below 3500.
Old 12-24-2011, 08:25 PM   #8
Turd Gen Guy
1nasty86's Avatar
should make for a nice combo!
1nasty86 is offline   Reply With Quote
Old 12-25-2011, 10:38 AM   #9
Your heading in my direction. I just added a FAST LSXRT I am going through some tuning issues but I can feel power picked up everywhere across the board.
I think a TBSS intake would be a nice addition as well. Much simpler tuning and install. Maybe not as good but gains are gains.
Should be a real nice driver with whatever intake you pick.
evand is offline   Reply With Quote
Old 12-25-2011, 12:57 PM   #10
charcoal03silvy's Avatar
for towing, i don't see a FAST intake worth the cash IMO. A TBSS or l92 setup would be my option.
charcoal03silvy is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
8.1 / 4L80E towing review Oobray 8-Lug Truck Performance 58 02-13-2016 01:38 AM
Supercharger for towing or cam & headers 2500ZL1 8-Lug Truck Performance 60 01-25-2016 07:30 AM
Budget turbo 4.8 van Zizzle PROJECTS GALLERY 11 10-15-2015 05:21 AM
408 Problems chevy6.0fan GM Engine & Exhaust Performance 4 08-20-2015 08:10 PM
Best rear gear and brand USMCvet0311 GM Drivetrain & Suspension 13 08-14-2015 11:28 PM
Tags
2001, 317, 408, build, dodge, engine, fast, ford, intake, ls, mopar, motor, stroker, tbss, towing
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
