What differntial in 2016 6.2
Old 03-01-2017, 09:19 PM
CDN SS's Avatar
The 3.42 and 3.73 9.76 carriers are different than the 3.23 so we cant just swap the R&P
I tried to get the dealer to do that on my new order .........no GM 3.73 R&P for the 3.23 carrier although I hear someone making a ring gear spacer to use with 3.73 gears ......
gonzo 6.2's Avatar
you ordered a SLT?
you are saying the SLE and all terain get the 8sp there for its a 3.42 max tow
And that SLT 6sp max tow is 3.73? Am i undersanding correctly?
Old 03-01-2017, 09:27 PM
CDN SS's Avatar
Actually I ordered a SLT with All Terrain package
the 5.3 with Max towing is not available in SLT Max Towing with 5.3 is 6 spd only but gets 3.73 9.76 rear
6.2 is only available in SLT / denali with 3.23 with I assume 9.76 rear
Max towing with 6.2 is 3.42 gear
Hope that makes sense I did not key in all the combos with 5.3 Max tow but for sure does not come up when you select SLT
Old 03-01-2017, 09:30 PM
gonzo 6.2's Avatar
Did you order a 6.2?
Old 03-01-2017, 09:32 PM
gonzo 6.2's Avatar
Why not order a 6.2 SLT max tow 3.42? because you wanted the all terain addition which doesnt have the max tow?
Old 03-01-2017, 09:36 PM
gonzo 6.2's Avatar
you can get a max tow 5.3 SLT but it will be a 3.42
Old 03-01-2017, 09:55 PM
CDN SS's Avatar
Yes 6.2 did not want Max tow as came with the big mirrors .......so will regear to 3.73 if possible
NO max tow with 5.3 with any gear comes up for me when you select SLT package but yes a 5.3 with 3.42 9.5 rear end is std in a SLT but Max Tow pkg not available from what have no only max tow in SLT is the 6.2 on my screen
Old 03-01-2017, 10:04 PM
gonzo 6.2's Avatar
Build & Price: 2017 Sierra 1500 Truck | GMC
click on selected packages,it shows SLT max tow
Old 03-02-2017, 10:16 AM
CDN SS's Avatar
click on selected packages,it shows SLT max tow[/QUOTE]
OK .... this is why its confusing .....what you show there is the Max tow for the 6.2 if you go further you would see the 5.3 8spd was kicked out and you need to select 6.2 .....
.In the SLT package only 1 Max Tow pack available it forces you to the 6.2
3.42 9.76 axle
But when you go into the lower models it will show
2 Max Tow packages ....this is the one that forces you to select 6.2 8 spd auto
and Max Tow 5.3 which which is 3.73 9.76 axle only with 6 spd auto
Anyway my point was the towing wts for the
5.3 with Max tow 3.73 and the 6.2 with the 3.23 axles ( no max tow) are the same which I found surprising about 9600lbs for each
Old 03-02-2017, 04:12 PM
gonzo 6.2's Avatar
3.42 9.76 axle
5.3 with Max tow 3.73 and the 6.2 with the 3.23 axles ( no max tow) are the same which I found surprising about 9600lbs for each[/QUOTE]
I get your point,my point was you can get a NHT max tow 5.3 SLT
This could make it simple according to GMC.com chat this truck is a NHT 5.3 8sp SLT Max tow 3.42
2017 GMC Sierra 1500 at Your Area Tacoma GMC Dealer - 3GTU2NEC3HG278135
