Questions about lowering 14 Models
Old 04-23-2014, 10:02 AM
FormerVendor
TheSuspensionSource's Avatar
Originally Posted by Bit
When you order a lift kit for a 2014 it asks you to specify between aluminum front end and steal. Basically a 4x4 is steal and the Z71 is aluminum. The only difference in the kit I see is that on the aluminum ones the is a .250" spacers that's goes between the upper ball joint nut and the spindle. I would assume that there will be something similar to this with a drop kit.
I am wanting to put the aluminum spindles on my 2wd rcsb but I haven't had time to test fit the ball joints.
The Z71 2WD has been test fitted by Belltech. Magnuson Superchargers took their's to Belltech a few weeks back for a 3/5 drop.
Old 04-23-2014, 10:07 AM
FormerVendor
Originally Posted by Z1500
So I've got a 2014 4x4 that I'm trying to lower 2/4. It has aluminum components.
McGaughys didn't think their 2wd spindles would work on my 4x4 so they sent me front drop strut spacers. Basically you cut off your stock spring perch on your strut and slide these on. Yuck.
I'd really like a drop spindle so I haven't installed any of this yet in hopes someone will put out a spindle. If anybody wants to me to do test fitting, I can do it quick and am a machinist so can give above average feedback.
You can use Belltech's lowering strut for 2". Based on the info provided I don't know if a spindle would be worth your time. I know Belltech will void the warranty if the spindle is machined. I wouldn't be able to accept the spindles back as a return if modified either.
Old 04-23-2014, 11:45 AM
Z1500's Avatar
I wouldn't modify it at all unless I was going to keep it. Just saying if they want precises measurements or such. I could send them back my stock spindles so they can compare.
Old 04-23-2014, 11:49 AM
FormerVendor
I did speak to BT about the 4WD spindles, at this time they are not going to develop a spindle for that model.
Old 04-23-2014, 03:16 PM
racerkvn's Avatar
That may be my High Country that you were referring to. It is a 4wd and I did piece together what I wanted. I have my Belltech 647 SP kit left over from my 13 crew cab that I was going to try the spindles from but honestly, I just haven't had a reason to try them yet. The route I took for mine has worked great for me, it aligned within spec, no driveline vibrations and drives/handles great. I've got over 3000 miles on it lowered with no complaints at all. I've checked everything over a few times and even after a few hard launches (or blowing the tires away in 2wd) everything seems to be fine.
Old 04-23-2014, 03:23 PM
FormerVendor
Old 04-26-2014, 08:22 PM
LSall1991's Avatar
any info on the djm 4-7 drop
Old 04-27-2014, 11:17 AM
FormerVendor
They just reused parts from the 07-13 model. Currently we are experiencing better customer feedback on the Belltech kits.
Bumpsteer is better, alignment is better and overall ride quality is much better. No vibrations and the rear wheels are centered in wheel well.
We have a 15% off coupon code you can use that expires tonight.
Old 04-27-2014, 11:27 PM
Registered User
Lifted2Lowered's Avatar
will the drop shackles for the 2014 rwd work with the 4wd models
Old 04-27-2014, 11:36 PM
FormerVendor
I do not have confirmation but I do not foresee an issue.
GXPJAY
02-13-2022 08:15 AM
Verz
08-21-2015 06:40 PM
thewrx
08-12-2015 08:28 PM
USMCvet0311
08-01-2015 07:45 AM
FlowmasterMufflers
07-17-2015 03:26 PM
Quick Reply: Questions about lowering 14 Models
