Oil change intervals?
KickinAssAndTakinNames
I think the factory interval is 6000 with Mix conventional synthetic.
Now that I'm doing my own changes with mobile one full synthetic and a k&N filter, I was thinking 8-10k miles between changes.
What do you think?
What do you think?
So I ordered a sample kit, and went ahead and changed my oil today at about 7k miles.
But something strange with the new filter.for some reason k&n specs different filters for Silverados vs Sierras....
Last oil Change I looked up the filter for a Silverado in the book. Today I looked up Sierra instead. Should be the same but when I got home I had this...
From my last oil change on the left the one I bought today on the right. What the hell? Didn't have time to go back to the store today so I went ahead and put the new smaller filter on.
the HP-2011 is the one I've been using, I've seen the other one, it's a little less capacity but otherwise identical.
I have always run Mobil 1 full syn and have always run it 7,000-10,000 miles with filter change/top offs mixed in there along the way. I've had analysis done before and never had a bad report. All of that data was from my 2001 and 2008 trucks though... that being said, I don't expect much to change with the new one and will most likely continue the same trend.
I'm running the M1 0/20 Dexos full syn in my 2014 also... truck is just over 32,000 miles
I did an oil analysis the last time I had my oil changed, and Blackstone labs said I could easily extend my oil interval to 8000 miles. I had 6300 on that oil change.
If you use a good filter, and a good oil. Why not.
Corvette454l88
09-01-2016 01:24 AM
Mossyoakglock
08-28-2015 12:49 PM
thewrx
08-12-2015 08:28 PM
Suburban2500
07-19-2015 04:50 PM
