Dyno fbo 6.2 e85
Old 07-05-2016, 12:09 PM
15dnali6.2's Avatar
Default Dyno fbo 6.2 e85
Going Thursday for a dyno tune on e85 with full bolt ons. 6.2 a8 4x4 stock wheels and tires. Any guesses on numbers? I'm in south Louisiana and it will be probably 95+ degrees.
Old 07-05-2016, 12:11 PM
FFDP's Avatar
As long as the factory driveshaft doesnt grenade on the dyno, over 400 I bet.
Old 07-05-2016, 12:17 PM
15dnali6.2's Avatar
Hopefully not. I'm guessing 410 being its hot as hell in south Louisiana this time of year. If it were January I'd guess 430
Old 07-05-2016, 01:11 PM
DuncR6's Avatar
380...interested to see the results though. Will you have a graph showing RPM on the x-axis?
Old 07-05-2016, 09:21 PM
15dnali6.2's Avatar
I should. Not sure what system he uses.
Old 07-07-2016, 04:14 PM
15dnali6.2's Avatar
Made 415 in 4th gear. Not sure how to calculate what it would make in 6th which is 1:1 ratio. 98 degrees in the shop.
Old 07-26-2016, 03:35 AM
62nalide's Avatar
I've got a bolt on 2016 Denali 6.2 also man what's all needed for E85 conversion?
Old 07-26-2016, 11:46 AM
15dnali6.2's Avatar
The easiest way is to order the kit from cjtunes.com then have your tuner activate the timing/fuel maps that already exist in the ecu. The other way would be go to a dealer and find a 5.3 flex fuel truck in the exact same body style as yours, get the vin from it then get the parts department to order all of the fuel lines that are different between the two and get your tuner to activate. The installation on the cjtunes.com kit is really easy minus the frame coating getting all over you haha.
Old 07-26-2016, 11:49 AM
15dnali6.2's Avatar
I guess I should also add that mine averages 15.5-16 mpg with cruise between 75-80. Towing a 18' gatortrax mud boat it averages 10mpg cruise set on 75. I haven't pulled my camper yet on e85 to give a number but the all around power is awesome.
cwalker2006
05-11-2016 10:03 PM
Wadsworth77
05-04-2016 07:10 AM
Batass
25
04-29-2016 12:45 PM
XwalkerX
04-25-2016 12:04 PM
BDR5oh
04-07-2016 02:02 PM
Quick Reply: Dyno fbo 6.2 e85
