Double Adjustable Shocks
Old 11-02-2016, 11:01 PM
ZO6Ted's Avatar
Default Double Adjustable Shocks
Anyone know of anything for 2014? All I can find is Rancho 9000 Struts and I guess they are only single adjustable. I thought I would order some and get my 60' better before I pulley down. Want to do it immediately.
Old 11-03-2016, 04:58 PM
musclecity85's Avatar
are you looking for rear shocks? if so you can just measure from the center mounting point of each bolt and get the extended and collapsed lengths and then call somewhere like viking or qa1 and they can find something for you. As far as front struts i dont think youll find anything unless you switch to a coilover setup
Old 11-03-2016, 05:24 PM
ZO6Ted's Avatar
Yeah just the fronts. They hit full extension when I leave even at idle. I would love to get up on the converter!
Old 11-03-2016, 07:14 PM
if you have the coin i would go coil overs. i think they sell an upper mount that will bolt in. you would probably have to scale the truck to get the front weight so you could order springs to get you the ride height/quality you were looking for. then it would be measuring for shock length from there
Old 11-03-2016, 09:06 PM
Resident Retard
BlackGMC's Avatar
Put a 1in spacer on the upper stude mount to gain an extra in of travel. Seems to be working just fine. Basicalky the spacer goes in the stud then the poly/rubber bushings go on top of that. Simple and cheap.
Old 11-03-2016, 09:22 PM
ZO6Ted's Avatar
I dd with it loaded and of course unloaded at the track so I'm not sure.
If I cant find something stiffer I guess as a last resort maybe? Wish it didn't pull up so hard.
Old 11-04-2016, 05:09 AM
madmann26's Avatar
Quit complaining Ted. LOL.
Old 11-04-2016, 12:29 PM
ZO6Ted's Avatar
Hey Jessie I'm old! Plus I've been sick all week lol!
Old 11-04-2016, 12:44 PM
ZO6Ted's Avatar
Old 11-04-2016, 02:00 PM
Resident Retard
BlackGMC's Avatar
Oh you have struts. Since your 4wd should you be looking into travel limiters?
Quick Reply: Double Adjustable Shocks
