2015 Silverado new axles
Old 12-02-2016, 10:14 AM
MRW412's Avatar
Default 2015 Silverado new axles
The truck is a 2015 Silverado CCSB 4x4 3.42s. I'm trying to order new axles from Moser Engineering and when I called them, they told me there were 2 different axle lengths for the 2014+ GM trucks and they didn't know if the axle length were engine related or not. I searched online and CARID.com says the 2014+ GM trucks with the 9.5" and 9.76" use a 34.02" Yukon axle replacement. Whenever I look up the axles for a 8.5" rear end, it does not display the axle length anywhere. Can anyone verify that the new 12 bolt 9.5" & 9.76" use the same axle length and the 8.5" rear uses a different one??? It's my daily driver and I'm trying to avoid draining the diff, pulling the axle and measuring it, putting it all together, and then do it again in a few days when the new axles come in.
Old 12-02-2016, 10:41 AM
07Softail's Avatar
The 9.5 and 9.76 axles are the same BUT the SUV's are different. You want truck axles. The SUV's are longer. Yes the 9.5 and 9.76 use a different axle than the 8.6 the length is 864.18 mm which is 34.02 inches. I want your old axles!
RT
Old 12-02-2016, 11:10 AM
MRW412's Avatar
Originally Posted by 07Softail
The 9.5 and 9.76 axles are the same BUT the truck and SUV's are different. You want truck axles. The SUV's are longer. Yes the 9.5 and 9.76 use a different axle than the 8.6 the length is 864.18 mm which is 34.02 inches. I want your old axles!
RT
Thanks! I will order them 34.02" long. I'm not sure if you want my old ones. If your a member of the GM-Trucks forums (if your name is the same on that forum as this forum), you responded to this video on the 700 page vibration thread. I really want to get rid of the shake so I can start adding performance parts....
Old 12-02-2016, 12:20 PM
07Softail's Avatar
Yeah I want them... PM me
RT
Old 12-02-2016, 01:03 PM
MRW412's Avatar
will do after I get my new axles in
Old 12-02-2016, 04:20 PM
07Softail's Avatar
That'll work.
RT
Old 12-02-2016, 11:24 PM
Feed's Avatar
That'll work.
RT
Looks like you can save them, ...MRW I hope new axles sort out the problem.
Old 12-03-2016, 05:01 PM
07Softail's Avatar
Yeah I will true the outer flange surface and lighten the flange with some 3/4" holes between the studs.
RT
Old 12-08-2016, 06:51 PM
07Softail's Avatar
Update.... did the new axles fix it? Whats the part number on the Moser Axles?
RT
Old 12-08-2016, 08:04 PM
MRW412's Avatar
RT
I haven't ordered them yet. I've been working 7 days a week and I haven't had time to pull the axle and take measurements. I thought I had enough info about the stock axles from googling them but they need more dimensions. There isn't a part number for Moser axles since they are a custom order. I'll probably end up buying them from Yukon since they have them in stock.
