2014 Sierra RCSB
The afore mentioned shop sent it out to a driveshaft shop in Fort Worth (sorry I don't know the name) to have it cut.
Belltech, said if their flip kit was installed "correctly" then the drive shaft wouldn't have needed to be cut. I asked them if I needed to remove the driveshaft after the fact would it come out and they didn't have a response.
I had similar issue with a Mcnaughy 2/4 kit. It was the first one I did on a 2014. I removed the drive shafts to install the kit, when I went to reinstall it, it wouldn't fit. I called Mcnaughy and they weren't much help. Only told me that they never remove the drive shaft. After I loosened it all up the driveshafted install just fine and it all bolted up correctly. I learned the tricks and have done the others with no problems and don't remove the driveshaft.
