2014 Sierra RCSB
Old 10-21-2014, 05:55 PM
fabiangmc's Avatar
Default 2014 Sierra RCSB slow progress build
So finally installed my drop kit. Any suggestions on where to go get alignment done and get pinion angle set around DFW area?
Old 10-21-2014, 06:26 PM
bigsapper's Avatar
Get your alignment done at the dealership. Seriously.
You should not need pinion angle adjustments if you used the Belltech kit. Which kit did you use?
Old 10-21-2014, 06:28 PM
fabiangmc's Avatar
Yeah i was thinking dealership.
I used Djm kit.
Old 10-21-2014, 08:33 PM
bigsapper's Avatar
You may not need a pinion adjustment. A transmission shop should be able to get a measurement for you.
Not sure where in DFW you are, but I've had Distinctive Motorsports in Plano do my lowering kit and tweaking on it.
Old 10-21-2014, 10:40 PM
Slowest turbo build ever!
black00chev's Avatar
If your area is any place like mine, you have to go to the dealer since no one else's alignment heads can do over 18" wheels lol.
Old 10-22-2014, 05:21 PM
fabiangmc's Avatar
Did you have your drive shaft shortened after you lowered your truck?
Any yea i'm in a small town with not too many good shops around.
Old 10-22-2014, 06:43 PM
bigsapper's Avatar
I had to have mine cut 1.5".
Old 10-22-2014, 06:52 PM
fabiangmc's Avatar
How'd you get to 1.5"? Wondering if i should get mine cut the same amount or might it need different
Old 10-22-2014, 08:55 PM
bigsapper's Avatar
The afore mentioned shop sent it out to a driveshaft shop in Fort Worth (sorry I don't know the name) to have it cut.
Belltech, said if their flip kit was installed "correctly" then the drive shaft wouldn't have needed to be cut. I asked them if I needed to remove the driveshaft after the fact would it come out and they didn't have a response.
Old 10-22-2014, 10:02 PM
Bit
Bit's Avatar
I had similar issue with a Mcnaughy 2/4 kit. It was the first one I did on a 2014. I removed the drive shafts to install the kit, when I went to reinstall it, it wouldn't fit. I called Mcnaughy and they weren't much help. Only told me that they never remove the drive shaft. After I loosened it all up the driveshafted install just fine and it all bolted up correctly. I learned the tricks and have done the others with no problems and don't remove the driveshaft.
Quick Reply: 2014 Sierra RCSB
