2014 RCSB tune only racing
Formerly LS1 D3moN (2014-06-05)
Here's the vid of that race
Facebook Post
Pretty happy with it. i was hoping for a 14.3 - 14.4....so a 14.5, for first time out is pretty decent. Is faster then my old 2001 was when it was a stock ls1 with a tune.
monday morning...leave your race number on...cuzracetruck.
Very good considering the heat! You'll get those times or better in cool weather. With traction probably see 13.9x's.
FYI I was 9.13 @ 75 in 1/8th, 2.0 60' bone stock with a bed liner and cover (150 lbs). I'm 4wd and it was 65 degrees. The weather and traction was great. You'd be quicker and faster.
it's got a mcgaughys 4/7 lowering kit with another 1" drop shackle in the back to total 4/8 drop. i dont have a notch, but i do hit the frame every once and a while..
I have the same, at 3.5/6, but the front tires hit the fender liners on the highway sometimes.... are you running McGaughy's front struts? I'm running 305/40/22 all the way around, maybe that's the issue.... What size are your fronts?
305/40/22 is what i run in the rears. for fronts i run a 265/40/22 (30.35 tall). so i have a little over 1" height difference front to back (also why the rear is dropped 8"...to level it out a bit).
that 305/40....nitto?
