1st 2014 Supercharged gm Denali 6.2 with mods. 1/4 mile
#32
Launching in 4WD, then switching to 2WD after the launch I get these numbers:
13.91 1/4 mile at 105 mph. 60' was 2.32 sec. 1/8 mile was 9.10 @ 81 mph. 0-100 mph was 12.74 sec. Those are my best times to date. Not track times but from a phone app accelerometer. It seems to be pretty accurate.
That's naturally aspirated, long tube headers, C7 intake manifold, CAI, and custom tune.
#34
#35
I don't think that is correct. If you launch in 4wd, then switch to 2WD while in 1st and WOT, it will go to 2WD at the 1st shift without letting off the gas pedal. The ecm is, in a sense, letting off the gas momentarily during the shift.
#37
I guess I will have try that out, but the problem is that my truck with all the power just rips the tires through first and second as well as the bottom of third, so,I will have to switch frm 4 to 2wd in a higher gear. I guess another test would be to switch from 4 to 2 while I am still in first. But I will bet my house that you actally have to let off the throttle for at least a second or so for it to switch back into 2 wd.
