silverado 6.2L numbers
Old 08-01-2015, 04:27 PM
rednekferlife101's Avatar
Default silverado 6.2L numbers
hi, this is my first post on here so not really to sure if this is where this belongs or not? but I have a 2012 Silverado ext. cab short bed 4x4 6.2L that I have a Maggie tvs1900 on running about 8psi, a texas speed vvt2 cam, circle-d multi disk 3400 stall converter, arh 1 3/4" long tube headers, hi flow cats and borla cat back. it has the rough country 2.5" level lift on a 285/70r17 mud tire. I got it dyno tuned and she put down 465hp and 508 ft. lbs. I was hoping to get a little higher numbers out of this set up... do those numbers seem right to the rest of you fellas with close set ups? thanks!
Old 08-01-2015, 05:33 PM
Formerly ScreamingL
George C....'s Avatar
ive dyno'd a stock 6.2 with a tune and it was around 335 rwhp and 380 rwhp torque on a dynojet
8psi should net ya 20 rwhp per psi from a small blower like that
you have small headers for a 6.2, cats that are hurting ya some and depending on size of Y pipe and catback that may be hurting ya
also that small blower is a heat pump so they are probably keeping timing to say 10 or 12*
Old 08-01-2015, 05:55 PM
ya I was hoping for 550rwhp out of it... 465 seems very low. I was figuring on 330 rwhp stock plus 160rwhp from the blower, cam claims 70rwhp, then headers and hi flow cats and exhaust was sayin 30-40rwhp and a locked up converter at wot should help #'s too. the y pipe is 3" going into a 3.5" collector then a 3.5" single borla cat back.
Old 08-01-2015, 06:32 PM
vettelovralexand's Avatar
Seems low to me for a healthy 6.2 on 8 psi. Mud tires wont help along with all the other mentioned things. How many rpm are you turning it?
Old 08-02-2015, 08:28 PM
Registered User
07_4.8ECSB's Avatar
Numbers seem way low to me...I had a 2011 CC 2wd 6.2 with ARH long tubes and a tune and made 380 to the tire on a dynojet...seems 8psi and a cam should net a lot more than 80hp more to the wheels..
Old 08-02-2015, 09:38 PM
Restricted
JordanH's Avatar
Seems on the low side to me, and I'm guessing it's all in your tune. Are you running the factory fuel system? If your truck is not a flex fuel your already maxing out your injectors/pump. I think the flex fuel injectors are 52lb, so if your truck is FF your close to maxing them out anyways... May have something to do with it?
Old 08-03-2015, 02:17 PM
Registered User
07_4.8ECSB's Avatar
I believe all 09+ 6.2s in the trucks are the L9H which means they would all be FF...stock fuel system should be fine on 93 octane
Old 08-03-2015, 03:35 PM
Restricted
JordanH's Avatar
Correct! I forgot about that... The base fuel pressure under WOT will drop some, but the 52lb stockers are still fine for that on 8 psi... Probably close to 90-100% IDC though.... I'm gonna bet it's your tune, probably on the conservative side.
Old 08-03-2015, 09:57 PM
The maggie blower came with injectors that I believe are 65 lb. and it's on the stock flex fuel pump. It was tuned when I took it to get a dyno tune it was stalling and rpm dipping and jumping coming to a stop. They picked me up 17hp and 72ft lbs on the dyno tune from tuning and locking up the converter. I believe they took it up to 6500rpm on the dyno. And I really wasn't happy with those #'s but the guy at the shop told me my mud tires are heavy really killing dyno #'s but I can't see a tire eating up 100hp that I was hoping for more haha. Thanks for all the replys though guys!
Old 08-03-2015, 11:05 PM
Formerly ScreamingL
my 35s dont rob me no where near as much power as ppl claim, i saw 10 rwhp difference between them and the stockers
Quick Reply: silverado 6.2L numbers
