Silverado 6.2 intake manifold pcv fittings?
Old 05-06-2016, 11:35 PM
rednekferlife101's Avatar
Default Silverado 6.2 intake manifold pcv fittings?
Does anyone make a pcv fitting that goes on the top of the l9h/l92 truck manifold in place of the hard line to convert it to a hose barb to run rubber hose to a catch can? i cut the hard line off the twist in fitting but there is only 1/4" or so of a nipple sticking out so I can't get a rubber hose to seal good to it.
Old 05-07-2016, 12:53 AM
FetzerValve's Avatar
In for answers
Old 05-07-2016, 12:41 PM
Wolftrk99's Avatar
What year intake are you running? The 07-08 had a typical pcv hose barb....
Old 05-07-2016, 12:47 PM
Wolftrk99's Avatar
Like this....
Old 05-07-2016, 12:51 PM
Mine is a 2012 6.2L l9h. The fitting in my picture pushes in with the o ring then turn it so it locks under the tabs... Guess I messed up by cutting the hard line off to try and get a rubber hose on it. I'll have to buy another whole hard line assembly for $10 and cut it an inch or so back from the fitting and slide a 3/8" pcv hose onto the hard line it's a tight fit so it shouldn't leak maybe put a hose clamp or zip tie on it
Old 05-07-2016, 01:16 PM
Wolftrk99's Avatar
Get the barb fitting for a 08 yukon..... And 5/16 hose fits tighter on the plastic line..... Just checked my 5.3 and its got the same twist in style with the barb....
Old 05-07-2016, 01:23 PM
That fitting on the Yukon is part of the intake it's glued or plastic welded on. Like the piece that the fitting goes into on mine is glued on the intake it doesn't just unscrew out so I can't swap to those barb fittings...
Old 05-07-2016, 01:52 PM
Wolftrk99's Avatar
I do have an ly6 intake with the hose already cut, if you want it.... Ill get a pic later
Old 05-07-2016, 02:10 PM
Ya if you could get me a picture of it that be great! Thanks
Old 05-07-2016, 09:20 PM
Wolftrk99's Avatar
Currently has a 5/16 line on it that fits rather snug...
Quick Reply: Silverado 6.2 intake manifold pcv fittings?
