service stabilitrak/service traction control, why does this keep coming on? - PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 11-08-2011, 01:25 PM   #1
Default service stabilitrak/service traction control, why does this keep coming on?
while driving my truck, it will occasionally show service stabilitrak/service traction control on the cluster. of course, it will chime a few times, and flash some lights on the cluster (traction control, abs, brake).
restarting the truck will clear everything, and its not throwing any codes when i check. whats going on?
Ieatpeople is offline   Reply With Quote
Old 11-08-2011, 01:34 PM   #2
01PewterWS6's Avatar
Pinched sensor wire or alignment out? Is it lowered/lifted? stock size tires?
01PewterWS6 is offline   Reply With Quote
Old 11-08-2011, 01:38 PM   #3
ak2007r6's Avatar
Probably a sensor going bad. I had an old truck that use to do that also.
ak2007r6 is offline   Reply With Quote
Old 11-08-2011, 03:00 PM   #4
I am having the exact same problem right now. Mine actually went into reduce power mode one time when the check engine light came on. Restarting the truck cleared it for me also.
dtoney08 is offline   Reply With Quote
Old 11-08-2011, 03:06 PM   #5
Quote:
stock height, stock sized tires (265/70-17), i've never had the alignment checked, but the tires wear evenly (never even been rotated).
i will check on the sensor wiring. i just re-installed my trans over the weekend, but i've driven nearly 200 miles already and thought any problems would have shown up sooner.
about a week after i bought the truck, it showed the same message (only had 400 miles on it), turned out my intake temp sensor had come unplugged. but it also threw a code for the sensor, so i knew where to check. right now i have no reference point.
Quote:
if you figure it out before i do, let me know.
Quote:
but, its a 2010. i would hope the sensors last longer than 30k miles...
Old 11-08-2011, 03:12 PM   #6
ak2007r6's Avatar
Mine was an 07 and I think it had 50k miles on it when it started acting up
Old 11-08-2011, 03:27 PM   #7
well, if it keeps being a problem, i will eventually have to make a trip to the dealer. hate that place.
Old 11-08-2011, 03:30 PM   #8
ak2007r6's Avatar
Mine was weird. It would only show up after about 30 minutes of driving.
So what did I do? Traded it in on a 2011 and made sure they didn't drive it longer than 30 minutes LOL
Hope you get it figured out, I never did get a final answer as to what was wrong with mine.
Old 11-08-2011, 10:31 PM   #9
My 08 VMax did that a few times before I replaced the stoplight switch. My cruise would not engage when that happened also, so I figured a $20 switch was a good place to start, and BINGO!
HTH
Jeff
hot66 is offline   Reply With Quote
Old 11-09-2011, 07:28 AM   #10
i used the cruise control on the way home from work, and it worked fine. but that doesn't mean much, just may not have been acting up at that time.
i checked the abs sensor wiring, front diff, trans, transfer case wiring, and anything else that plugs in underneath the truck. all sensors were plugged in tight, no pinched wiring, no abrasion on any wiring anywhere. i guess the problem is one of the sensors itself.
Thread Thread Starter Forum Replies Last Post
2009 Chevy Colorado 5.3L V8 1 of 142! $17,200 Corvette454l88 Trucks and SUV Classifieds 19 09-01-2016 02:24 AM
Did my first oil change on it myself today... Noah Burns GMT K2xx Trucks General Discussion 5 09-07-2015 06:50 PM
ABS & Brake Light coming on at the same time 97aztecgt GMT 800 & Older GM General Discussion 8 08-13-2015 03:11 PM
Kooks Headers and Exhaust is Hiring! KOOKS Headers THE TRUCK STOP 0 07-27-2015 02:43 PM
4.8 tvs1900? hackrst FORCED INDUCTION 11 07-11-2015 12:17 PM
Tags
1500, 2008, acts, brakes, coming, control, gmc, problem, service, sierra, silverado, stabilitrack, stabilitrak, traction, truck
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
