NNBS Lowering Questions answered here
#92
#93
djm 5/7 drop shock ?
I have a 05 silverado extended cab with a djm 5/7 kit with the djm shocks which are horrible and starting to chop the treads on my tires from all the bouncing. Any suggestions on a better shock or maybe coilover replacement? depending on price of coilovers that is.
#94
Since lowering my truck , the rear end make a lot of noise(squeaky) and the front is making noise going up driveways. Do I need to get new shackles(stock) or should I grease up the leaf springs? Should I grease up the ball joints on the lower control arm?
#95
Do you have polyurethane bushings if you do polyurethane bushings are notorious for making squeak sounds and need to be lubed with the proper lube
#99
FWIW, On my 2012 rcsb, I had 2509 spindles, 2" springs and struts set to 1" drop. I needed cam plates and offset bushings to get camber barely in spec. When i lowered my 2015, Same setup with 2511 spindles/springs except struts set for 1/2" drop, I maxed out the camber adjustment before I set it on the ground the wheels were like \--/ Way too much positive camber, probably just could've use the offset bushings.
