Need help with Suburban
My in-laws have an 07 Suburban with a 5.3l. A couple months ago we rode with them to the beach and everything was good until we got nearly back home. It started having a misfire at idle randomly. It has been doing that ever since but still running fairly well besides that.
On thanksgiving day they took it on a little trip and it shut off on them. My father in-law said it sounded like a diesel for a second and then shut off.
They had it towed back home and I was able to check the codes this morning and it's showing p0016.
It says "crankshaft position-camshaft position correlation bank 1 sensor A."
It will turn over and it sounds like a cylinder or two might be trying to fire but it will not start.
Maybe needs a new Crank position sensor and a relearn? They have another vehicle to drive so it's not an emergency but I'd like to fix it for them so they don't have to pay somebody.
Thanks,
Joey
Thanks,
Joey
I forgot to ask, but if we end up changing the crank position sensor and/or cam position sensor do we need to have a crank relearn done anway
Joey
Joey
Lab scope is another name for an oscilloscope, youd be able to see actual cam/crank signals and correlation.... But its a mute point if you dont have( or have access to) one.....
Brick, i thought they relearned themselves automatically when you cranked the engine??!! Maybe thats older gm's..... Havent seen too many cam/crank sensors go bad on gm, usually fords nissans and chryslers i see crank/cam sensor problems on... Not to say its not unheard of but kinda rare...
OP is this a nnbs suburban..... Could be broken timing chain tensioner, or sonething goin on with chain.....if you can "borrow" good known sensors i would go that route first though before tearing into the engine.......
Custm2500's Rude Friend
Hence the reason they put the relearn feature in the scan tool software. They now have a feature in some of the tuning software to copy over the learned data when flashing a tune.
I haven't seen very many fail either. I would also suspect a mechanical issue of sort.
Hey guys he's been busy this week working, but said he just swapped the Crank position sensor. Still won't start. I'm sorry I know I'm not much help I've never been inside one of these engines (yet) and I know it's even harder to diagnose something over a computer.
I assumed if the crank/cam sensor was the problem it would run if they were changed, and then get the relearn after. I was just thinking maybe something happened with the timing chain but I've never heard of one breaking. I don't know if this helps any, but this thing does have AFM and burns a good bit of oil.
