How to wire in boost gauge?
I have a gauge for that
DIC is driver information center I think, the message area on the cluster.
You can use a wire splice or strip away from insulation and solder your wire to the one you are taping and seal it up with heat shrink or tape.
As a note, most LEDs do not dim like normal lights, they are pretty much either on or off.
They are retained accessory power ports that are under the dash in the black box. Do a search for the pinouts online and use them to power things like gauges that you want on and off with the regular accessories. Mine come on with the key and go off like the radio does when you open the door.
