GMT900 Hydroboost Conversion How-to
#31
If i cant get it to ohm right then i'm thinking about having my bcm flashed finally.
Yes i have the whole write up with what p/n i used and how i spliced the high pressure hoses. The master i bought used the same lines without adapters.
I would look at your master to see how wide it is then go to the part store to compare. I used all AC Delco parts on mine which i ordered online for a lot cheaper
#33
10 Second Truck Club
I just finished a hydroboost conversion on my truck which is a 07.5 and it turns out i dont have any "sensors" to deal with on my vacuum booster. The master cylinder off an 08 2500HD gas truck was a direct fit in thread pitch and line spread. I also installed a T fitting for the return lines instead of replacing the pump which i also have from the HD truck. I must have gotten lucky on mine but it is basically a W/T trim model so that may be why lol.
#34
Great write up ! Just did mines . Was very helpful . Like the guy above mine was pretty plug and play . Everything match up great .got everything from a 2500HD. Hydroboost was a great choice for me since I’m turbo . Truck feels way better and stops in a dime . Thanks again !!
#36
#37
07 Avalanche hydro boost / service brake light
I did this resistor install on my 07 Avalanche and it did nothing. Do you have any other ideas that might help? The relay clicks when I hit the brake, but service brake light is still on and as soon as I start to move, stabilatrac and traction control go off as well. My booster had two sensors in it. The one three wire vacuum sensor and a two wire that appears to be a pressure sensor. Any help would be appreciated.
#39
'12 AWD Platinum Escalade
Well, I believe that I figured it out, and posted instructions here: https://www.performancetrucks.net/fo...-c0299-559296/
This fix may only apply to the rotary brake sensor trucks (2012+); as someone with an '07 was unable to get this to work for him. It could also be that the voltages to the EBCM just need to be slightly higher or lower for the earlier GMT900s.
I'm happy to help, and you could certainly try my "Service Brakes Soon" fix before doing a hydroboost conversion.
Snddoc1 (11-11-2023)
kelchie
08-17-2007 12:22 AM
