Dod delete part list
Old 12-17-2011, 04:09 PM
iamkeniff's Avatar
Default Dod delete part list
this is a list to do a DOD delete on a 5.3, the same thing would go for the 6.0 and 6.2 but you would need L92 head gaskets *ONLY IF IT HAS DOD ALSO* but you'd have to purchase the front cover.
LS2 timing cover sensor gasket and seal 12633906 (only needed if you have VVT)
Cam Gears *there are 2 options*
Single bolt *you already have this cam gear if you have a 4.8/5.3*
3 bolt
Part Number: 12586481
Head Gaskets
Part Number: 12498544 *this is for 2 5.3 head gaskets, not the single pack*
LS7 Lifters
Part Number: 12499225
LS2 Dampener *i recommend to swap this because the factory tension is JUNK*
Part Number: 12588670
Lifter Guide *you need 4 of these*
Part Number: 12595365
Valley Cover *without AFM and without the PVC vent (known as the 4.8 valley cover. it is just like the LS3/7 valley cover just half the price)*
Part Number: 12598832
LS9 head gasket: 12622033 *you need 2*
L92/LS3 (6.2) head gasket: 12610046 *you need 2*
6.0 head gasket: 12589227 *you need 2*
info added from AUTOT3K
non VVT front cover: 12633906 (only needed if you have VVT)
Various Gaskets
Water Pump X 2 12630223
Valve Cover X 2 12637683
Oil Pump O-Ring 12584922 - orange
ARP Head Bolts for 05+ block 134-3610
ARP LS crank bolt (except LS7) 234-2503
ARP cam retainer plate bolts 134-1002
ARP cam sprocket bolts 134-1003
Your total for the cam/dod delete with parts will range about 1600-1700 depending where you can save on costs
Old 12-17-2011, 04:21 PM
08cheyennesc's Avatar
Sticky
Old 12-18-2011, 03:15 PM
GMCSIERRA5.3's Avatar
Good.info x2 on sticky
Old 12-18-2011, 04:49 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
I agree, good info.
Let me know when you get everything organized in your 6L80e swap thread and Ill stick it too.
Old 01-08-2012, 08:54 PM
ncange4's Avatar
i was also doing some reading that the diablo tuner gives you a choice to turn it on or off will you have any problems if you do it this way for the time being ?
Old 01-29-2012, 06:28 AM
Slow91z's Avatar
Same question as the dude above me...if you just want a stock truck that doesn't turn off cylinders and you just turn it off with the tune and be done?
Old 01-29-2012, 11:20 AM
That will be fine, it just needs to be done when you will be running a high lift cam it not then just turn it off in the tune.
Old 02-12-2012, 09:57 PM
kyles06crew's Avatar
So on the cam gear all I have to do is change it to a 3 bolt and that's it?
Old 02-17-2012, 12:26 AM
Silverado53's Avatar
Yes if changing to a three bolt cam, the three bolt cam gear is all thats needed, unless you wish to change the whole timing set/tensioner.
Old 05-27-2012, 11:36 AM
iamkeniff's Avatar
weee
Quick Reply: Dod delete part list
