Dod delete part list
Old 09-19-2014, 11:19 PM
  #51
LS1TRUCKGUY's Avatar
Originally Posted by 01Sierra
What about superchargers??? Do they still have the same problems with the lifters???
Superchargers do the same thing turbos do. DOD lifters take a **** by themselves even without the help of aftermarket power adders.
esoteric_ast (10-09-2019)
Old 09-26-2014, 06:26 PM
  #52
MASS seller approved
mitchellmade's Avatar
when deleting vvt should the second cam bearing be changed ? or are they the same bearings and just cam is different? about to put a ls9 cam in my ly6
Old 09-26-2014, 08:29 PM
  #53
iamkeniff's Avatar
Why would you change cam beaings unless there is a lot of wear. If that is the case then you should rebuild/buy new motor.
Old 09-28-2014, 03:47 PM
  #54
Wasn't sure if bearing W's different for a vvt cam
Old 09-28-2014, 05:33 PM
  #55
They are the same...no need to change them.
Old 01-29-2015, 11:32 AM
  #56
mdwatts11's Avatar
I copied this from my cam swap thread, but I thought it would be easier for folks to find here. These are all of the parts I used IIRC.
-ISKY Triple 12 (Stock 48 $389 shipped)
-LS7 lifters (GM 17122490 $129)
-Alper Head studs (GEN IV head studs $109.50)
-BTR hardened pushrods (PR7350312-16 $94)
-LS9 head gaskets (GM 12622033 $47 EACH)
-TSP Ported LS6 oil pump (25-TspPortedPump $189)
-LS2 timing chain (GM 12646386 $40)
-LS2 tensioner (GM 12588670 $15.61)
-4x 3 bolt cam gear (GM 12586481 $26)
-Arp cam bolts (ARP 134-1003 $9.30)
-LS2 lifter trays (GM 12595365 $8 EACH x4)
-BTR springs (SK001 $229)
-Comp trunion upgrade (13702-KIT $131)
-ARP crank bolt (234-2503 $27.99)
-LS7 crank bolt to put balancer on (GM 11570163 $8.50)
-4.8L valley cover (GM 1259832 $42)
-10' 5/8" heater hose
-2 brass 3/4" elbows (all Home Depot had and they work fine)
-2 brass 3/4" couplings
-hose clamps
-new gaskets all around except valve cover and int/exh manifolds (TSP 28-CamGskKit $61.99)
-Arp thread tap
-mineral spirits and plastic scraper for cleaning head surfaces
TOTAL $1,627.93. This doesn't include the misc stuff I bought at the auto parts store like spark plugs, fluids etc.
Old 01-30-2015, 11:57 PM
  #57
iamkeniff's Avatar
I'll add your pricing info into the first post so it's easier to get a pricing run down for everyone
Old 07-22-2022, 02:11 AM
  #58
02tahoelt's Avatar
Originally Posted by iamkeniff
this is a list to do a DOD delete on a 5.3, the same thing would go for the 6.0 and 6.2 but you would need L92 head gaskets *ONLY IF IT HAS DOD ALSO* but you'd have to purchase the front cover.
LS2 timing cover sensor gasket and seal 12633906 (only needed if you have VVT)
Cam Gears *there are 2 options*
Single bolt *you already have this cam gear if you have a 4.8/5.3*
3 bolt
Part Number: 12586481
Head Gaskets
Part Number: 12498544 *this is for 2 5.3 head gaskets, not the single pack*
LS7 Lifters
Part Number: 12499225
LS2 Dampener *i recommend to swap this because the factory tension is JUNK*
Part Number: 12588670
Lifter Guide *you need 4 of these*
Part Number: 12595365
Valley Cover *without AFM and without the PVC vent (known as the 4.8 valley cover. it is just like the LS3/7 valley cover just half the price)*
Part Number: 12598832
LS9 head gasket: 12622033 *you need 2*
L92/LS3 (6.2) head gasket: 12610046 *you need 2*
6.0 head gasket: 12589227 *you need 2*
info added from AUTOT3K
non VVT front cover: 12633906 (only needed if you have VVT)
Various Gaskets
Water Pump X 2 12630223
Valve Cover X 2 12637683
Oil Pump O-Ring 12584922 - orange
ARP Head Bolts for 05+ block 134-3610
ARP LS crank bolt (except LS7) 234-2503
ARP cam retainer plate bolts 134-1002
ARP cam sprocket bolts 134-1003
Your total for the cam/dod delete with parts will range about 1600-1700 depending where you can save on costs
Is this parts list for a DOD delete or VVT delete, And/or both?
Also does everyone recommend going all ARP, or with New OEM bolts?
5.3Caprice
11-07-2015 08:56 PM
MattOKC
08-18-2015 11:30 AM
Matt331
07-26-2015 09:40 PM
EscaTruck
07-20-2015 11:42 AM
Quick Reply: Dod delete part list
