Anyone ever got a P0507 code after cleaning throttle body? - PerformanceTrucks.net Forums
Thread Tools Search this Thread
Old 07-02-2010, 09:05 PM   #1
007gmc's Avatar
Default Anyone ever got a P0507 code after cleaning throttle body?
Cleaned the throttle body on a 07 Tahoe 5.3 now it gets high idle code and when you rev it up it will idle around 2-3 rpm. If you start it up and don't rev it it will idle at normal rpm but as soon as you rev it it will not come back down to idle. Tried relearning the idle with a tech2 didn't help. Tried a new throttle body same. Smoked the intake showed no sign of a vac leak. Fuel trims are normal. The Tahoe is all stock right over 100k. Any help appreciated.
007gmc is offline   Reply With Quote
Old 07-04-2010, 01:47 AM   #2
Custm2500's Rude Friend
1FastBrick's Avatar
When you swaped the TB did it have a new TPS sensor or did you re-use the one from the original TB???
1FastBrick is offline   Reply With Quote
Old 07-04-2010, 01:51 AM   #3
007gmc's Avatar
it was all new and remeber this is a dbw tb no external tps
Old 07-04-2010, 01:53 AM   #4
1FastBrick's Avatar
Quote:
I know 07 is DBW but i thought they had an external sensor that was bolted on???
No other codes???
Old 07-04-2010, 02:25 AM   #5
LowBlack99's Avatar
Did you take the air intake off completely or just off the throttle body? If completely, you had to unplug the connector at the MAF, might not be fully reconnected or a pin got bent? Also check the little tube that hooks into to air intake on the left side just before the TB and make sure its connected at both ends.
LowBlack99 is offline   Reply With Quote
Old 07-04-2010, 12:56 PM   #6
007gmc's Avatar
Quote:
No other codes???
Nope just the throttle actuator. It had a evap code that i fixed, I did a oil change, cleaned the throttle body, replaced a air bag sensor and replaced the accessory belt.
Quote:
I took the throttle body off completely to clean it the intake tube came off at the tb side. The tb plug was the only thing I unplugged from the harness. I checked the air tube on the valve cover its in place. The maf reads fine, the throttle can be command with the tech2 when idle is normal. When it idles high its at 22% throttle actual tps and commanded buy truck. When it idles up like that the tech2 will not longer command the throttle. At this point im totally stumped.
Old 07-04-2010, 02:04 PM   #7
2007chevy5.3l's Avatar
When I took mine off to clean/polish it up I had this problem. Turned out being the butterfly was binding up in the bore because I didnt align the butterfly back up right
2007chevy5.3l is offline   Reply With Quote
Old 07-05-2010, 09:43 PM   #8
007gmc's Avatar
Quote:
ill check that but i never removed the butterfly
Old 10-13-2010, 12:25 AM   #9
Registered User
I know this post is kinda old, but Im fighting the same issue. What did you have to do to get it fixed? I really appreciate the help.
rare86 is offline   Reply With Quote
Old 10-13-2010, 12:41 AM   #10
Mrgoodwrench3's Avatar
I have cleaned probably over 1000 GM T/B's and have not had this problem. Usually it's a low idle and it comes up after cleaning. I would look at the desired and actual TPS request. What is the short term fuel trim % ? I would remove the intake boot and make sure the throttle body opens with out binding and recheck for any vacuum leak.
I know I just asked you to recheck everything that your first post said but sometimes easy mistakes are over looked. I have learned the hard way too many times....
Mrgoodwrench3 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
FAST LSXRT & Nick Williams 102 Throttle Body jdb11386 GM Parts Classifieds 29 12-03-2015 10:34 PM
2001 Sierra not entering idle adapt spark control smokeshow Tuning, Diagnostics, Electronics, and Wiring 2 08-23-2015 09:23 PM
mildly built 6.0, tuning nightmare from hell... noproblems209 Tuning, Diagnostics, Electronics, and Wiring 12 08-10-2015 07:57 PM
HELP NEEDED OBS LQ9 swap going into reduced engine power mode GreyChevy Tuning, Diagnostics, Electronics, and Wiring 1 07-07-2015 09:57 PM
iron transfer case adapter, ported throttle bodies, NP261 transfer case Gadgetized GM Parts Classifieds 0 07-07-2015 05:40 PM
Tags
07, 2000, 53, body, code, fast, gmc, high, idle, ls1tech, p0507, relearn, sierra, silverado, tahoe, throttle
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
