Adjusting Headlights Down after dropping rear?
Old 12-21-2009, 02:04 PM
ig109's Avatar
Default Adjusting Headlights Down after dropping rear?
Anyone know how to adjust the headlights down towards the ground? I cannot find anything under the hood other than left and right adjustments..
Thanks
Old 12-21-2009, 02:43 PM
08Chevy's Avatar
it should be right on top of the headlight when you pop the hood open. It takes a alan wrench to adjust.
Old 12-21-2009, 03:31 PM
ig109's Avatar
So the only adjustment is to loosen the two bolts and move the headlight down like that?
There is no deal to turn that works off of a solid mount ( like a cam or worm gear type adjuster)
I cant believe that is all they use.. Man they are getting cheaper..
Old 12-21-2009, 05:28 PM
SS94S10's Avatar
GM uses shims to lower the lights. Shitty way but that's what it is!
Old 12-22-2009, 09:42 AM
08Chevy's Avatar
There is like a white plastic piece that is right over the back side of the low beam houseing. I'll trying and get a picture of it for you but it will be a cell picture.
Old 12-22-2009, 10:39 AM
ig109's Avatar
GMC and Chevy the same? Im working on a GMC if they arent.. I know the lights are different but i assumed the radiator support, attaching points, and the adjustment procedure is the same..
Thanks for the help.. Tired of getting flashed all the time.. Accidentally flashed back at a cop and got pulled over.. NOT GOOD
Old 12-23-2009, 01:09 AM
09Jimmy's Avatar
I thought I was the only idiot here. One would automatically assume that because the only adjustment screw says <L and R> that they mean left and right, correct?
Turns out they mean Lower and Raise.
Old 12-23-2009, 01:15 AM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Now you know one of many GM trade secrets.
Old 12-23-2009, 02:03 AM
Dewey's Avatar
my lights have two screws, one on the top and one on the side.
JordanH
02-28-2017 07:22 PM
DarkhorSe_SS
08-20-2015 08:58 AM
Bluchevypick
08-18-2015 09:11 AM
Ketis
07-23-2015 12:37 PM
Blackrat48
07-11-2015 12:36 PM
Quick Reply: Adjusting Headlights Down after dropping rear?
